nitto 555r not hooking
Old Jul 14, 2013 | 12:51 PM
tigearl12's Avatar
Default nitto 555r not hooking
i just put some 555rs on my 99 t/a i have some mods about 430 rwhp. new bilsteens all the way around. problem i cant get it to hook at all tire spin and wheel hop out of the hole. tried different lbs pressure from 15 to 20 still not alot of difference . was it a mistake to put these on it . still running stock rear end 3:23 gears and auto with 2900 stall. wanting to go to 3:73 soon. ran 12.60s even with tires spinning and wheel hop. 1.90 60 ft time sucks . need some help.????
Old Jul 14, 2013 | 12:56 PM
HCI2000SS's Avatar
I'm running the same tires as you with around the same hp as you, but with 4.10's and a 6-speed. Anything less than a 2nd gear roll and I have no traction
Old Jul 14, 2013 | 01:00 PM
high impact's Avatar
TGEAR, I have seen a lot of guys running these tires. It appears these tires need a lot of heat to hook well with a stalled auto.
HCI, I wouldn't run radials with a 6 spd - I have never seen anyone have any good results with a radial and 6 spd. If you want to hook well stick with a bias tire.
Old Jul 14, 2013 | 01:06 PM
Sick Z28's Avatar
Get some hoosier they hook pretty good I had nitto and mickey's and couldn't hook for nothing
Old Jul 14, 2013 | 06:51 PM
Blackpanther99's Avatar
x2 on that one. Lol Not a good combination.
Old Jul 14, 2013 | 06:59 PM
Fallout8888's Avatar
As said above you need to heat these tires ups substantially, for the best results.
Old Jul 15, 2013 | 06:37 PM
Get some Hoosiers and youll be done.
Old Jul 16, 2013 | 12:49 AM
KTK Z28's Avatar
I agree for the most part.
Im running 397 whp (3.42 gear) on motor and hook on the track with so so prep. Hooks well on the street however. On the 150 shot I can hook on the street surprisingly well but have zero traction at the track even with prep. I'm talking about I can do a 3-5 second burn out and still spin at 100mph on spray with the 555R's.
I recently bought some 255/50/16 Hoosier drag radials and hook like a **** on the street or track on the 150 shot. This is without a burnout, just a short haze to clean the crap off the surface of the tire. Hope this helps.
Old Jul 16, 2013 | 01:29 PM
thunderstruck507's Avatar
Get them hot. By hot I mean 2nd gear burnout at a decent RPM for 7-10 seconds.
If you made 430rwhp through a stalled auto they just might not be the tires for you unless the track is prepped excellent and there are no street tire cars running before you.
Old Jul 16, 2013 | 02:33 PM
Tommyv8's Avatar
I sometimes spun those tires with 2.73s and a stock stall. With 3.42s and a 2800 stall traction was very hard to come by.
Old Jul 16, 2013 | 05:31 PM
happysem's Avatar
I agree with what most of these guys are saying, but I think we're overlooking half of the problem.
Fix that wheel hop, get LCA's and relocation brackets.
Old Jul 16, 2013 | 08:20 PM
OP... Any suspension mods?
Old Jul 16, 2013 | 08:42 PM
BODUKE's Avatar
Get a good burn out with smoke. Track prep plays a big role! Nittos 555r took me to 11.30's
Old Jul 16, 2013 | 08:48 PM
97ss497's Avatar
I did 1.6 60 foot times wth those tires.
Old Jul 17, 2013 | 12:49 AM
01ssreda4's Avatar
My best 60 with them was a 1.69 but it was hit or miss whether I could hook, stock suspension, well prepped track.
Old Jul 17, 2013 | 07:06 AM
JDEP162's Avatar
Nit to 555r, my first exp with drag radials, bI'm pleased. Street tires roasted at anything under 30. These grab from any speed even from a stop. Only timI've got them to spin is when the n2o hits, spin like a shift kit hitting tho, and grab right away. Track grip was good on motor. Small burnout.
