15x5 Weld RTS fitment on F-Body with 98-02 front brakes
Old 07-14-2013 | 08:02 PM
supernaturalta's Avatar
Default 15x5 Weld RTS fitment on F-Body with 98-02 front brakes
As the title states, I have questions pertaining to the fitment of 15x5 Weld RTS wheels on a 4th generation F-Body with 98-02 front brakes. I want the 15x5 because I drive my car on the street and also to/from the track. My intention is to find a 15x5 wheel that will: fit without grinding brake calipers and tuck inside the top of the wheel well. I understand a member here runs 15x5 Racestar Dragstar wheels that fit that criteria, and that may end up being an option for me, but I'd really prefer to have Welds.
I'm looking at Weld's online fitment guide.
http://weldracing.com/press/wp-conte...e-May-2013.pdf
It says a 15x4 low pad wheel with 2.5" backspacing (71LP-504B25A) will fit with a 1/4" spacer. Therefore, it would stand to reason that a 15x5 with 2.5" backspacing (71LP-505B25A) would also fit with a 1/4" spacer, but it would stick out 1" farther. Does anyone run these, and if so, how well do they tuck in, if at all?
Weld doesn't list this wheel in their F-Body fitment guide, but they do list a medium pad 15x5 wheel with 2.5" backspacing (71MP-505B25A) in their catalog.
http://weldracing.com/aitdownloadabl...itfile_id/309/
That might be an even better option, especially if it would fit without a spacer. Does anyone run these, if so, is it with or without a spacer, and/or was any caliper grinding involved?
I did a search and didn't really find anything; any and all input is greatly appreciated.
Old 07-30-2013 | 10:03 PM
loosews6's Avatar
Just get a gen 4 f-body lt1 cars are ugly no matter what wheels u put on them.....
Old 07-30-2013 | 10:16 PM
Guitar's Avatar
Yeah **** those third gen LT1 cars...oh wait.
Old 07-30-2013 | 10:18 PM
ltxMonte's Avatar
LT1s are fourth gens... A face lift and a motor doesn't change the generation, a complete body style change does. I don't have anything to add to the thread, I have ran a 15x6 street star but it was on the ugly lt1 brakes.
Old 07-31-2013 | 05:11 PM
You guys have to excuse Mr. WS6, he's a little slow.....
This is the same wing nut with a negative trader rating whose still trying to sell parts on this site.
Anyway, back to our regular scheduled programming.....
I'll probably just end up going with the 15x5 RaceStars in front because I know they'll fit without me having to grind through my brake calipers .....unless someone chimes in before I get the wild hair to buy wheels.....
Old 11-03-2013 | 02:12 PM
Firebirdmuscle's Avatar
What did you end up getting? 15x5 race stars or rts???
Old 11-06-2013 | 04:13 PM
I still haven't bought wheels yet.
Old 11-07-2013 | 08:55 AM
Tough decision. Wheels are a critical part to any build. I'll keep checking back to see your decision.
Old 12-04-2013 | 12:29 AM
bboyxclub's Avatar
Any update? Im in the process of trying to get some street/track ready wheels too.
Old 12-12-2013 | 12:36 AM
I haven't bought anything yet and I've basically put my car away for the winter.
Old 12-12-2013 | 12:52 PM
Dang man. Well what are you running on the rear?
Old 12-18-2013 | 01:18 AM
Chrome 16x8 5 star TA wheels and 27x10.5x16 MT ET Streets that I bought from a board member a couple years ago.
Old 05-07-2014 | 12:16 AM
I went ahead and got the RaceStars.
Front: RS92-550244 DP (15x5, 2.375" BS)
Rear: RS92-510254 DP (15x10, 7.25" BS)
I'll post an update and pictures when I get around to installing them.
Old 05-08-2014 | 01:57 AM
Good thing man. I forgot about this thread. I tried the 15x5 rts and they fit but stuck out out under the fender. I ordered a 15x5 but they sent the 15x5.3 but I don't know if that would have made a difference. Racestars should tuck/ or be flush with the fender with the tire mounted. At least in that one thread it was.
Old 05-08-2014 | 06:31 PM
That's interesting. Those Welds are supposed to be a 2.5" BS, right?
I've seen two people with the 15x5 RaceStars; both fit with no spacers/grinding, and the wheels didn't stick out past the fender.
Old 05-10-2014 | 01:50 PM
Yeah, they were 2.5 bs. That's what I was trying to explain to the weld rep but she was not understanding what I was trying to explain to her. She jut kept reading from their online page. Told me to make them fit I needed I put a spacer on. They already stuck out from under the fender, spacer would make it worse.
Old 05-15-2014 | 03:00 PM
Chalk these up as a great fit with no spacers or caliper grinding. The parts I used are as follows:
Wheel Studs: Moroso 46245; Press-In, 12mm x 1.5 in. x 3.250 in. Long, .509 in. Diameter Knurl
http://www.summitracing.com/parts/mor-46245
Lug Nuts: McGard 63002; Shank with Washer, 12mm x 1.50 RH, Open End, Chrome Plated Steel
http://www.summitracing.com/parts/mcg-63002
Front Wheels: RaceStar RS92-550244 DP (15x5, 2.375" BS)
http://www.summitracing.com/parts/rce-92-550244dp
Front Tires: Cooper CS5 Ultra Touring 185/65R15 88H
http://www.discounttiredirect.com/di...5&rd=15&cs=185
Rear Wheels: RaceStar RS92-510254 DP (15x10, 7.25" BS)
http://www.summitracing.com/parts/rce-92-510254dp
Rear Tires: Mickey Thompson ET Drag Slicks 3053S 26x10-15
http://www.summitracing.com/parts/mtt-3053s
I didn't weigh the rear wheel/tire setup, but the fronts are 17 pounds lighter per wheel/tire than the stock 16x8 wheels with 245/50R16 tires.
I'll let the pictures do the talking from here.
Attached Thumbnails 15x5 Weld RTS fitment on F-Body with 98-02 front brakes-ta_14may14_15.jpg   15x5 Weld RTS fitment on F-Body with 98-02 front brakes-ta_14may14_16.jpg   15x5 Weld RTS fitment on F-Body with 98-02 front brakes-ta_14may14_20.jpg   15x5 Weld RTS fitment on F-Body with 98-02 front brakes-ta_14may14_21.jpg   15x5 Weld RTS fitment on F-Body with 98-02 front brakes-ta_14may14_14.jpg
Old 05-16-2014 | 06:26 PM
Perfect.
Old 06-09-2014 | 12:24 AM
SPOOLIN Z28's Avatar
Do the rears fit with out grinding or spacers?
Old 06-09-2014 | 11:30 PM
wells01's Avatar
Will the backspacing on these rear wheels allow for a 28" tire?
Quick Reply: 15x5 Weld RTS fitment on F-Body with 98-02 front brakes
