Nitto 315's
Old May 3, 2004 | 01:55 PM
HAMRHEAD's Avatar
Default Nitto 315's
With all the searching there is still no clear cut answer so post any experiences. Will the Nitto 315's fit on a 17 x 10 wheel since I hear Nitto's sizes are actually smaller than other tires? If not will the Nitto 275's fit funny on the 17 x 10 rim? If it looks too small for the rim there's no point in getting the 555R's. Thanks!
Old May 3, 2004 | 01:58 PM
silverbeast's Avatar
yes they will. i just bought some for my 11 inch ttII's.
Old May 3, 2004 | 02:01 PM
Xsta Z 28's Avatar
Nitto says 10.5" minimum wheel width . . . .
Old May 3, 2004 | 02:03 PM
HAMRHEAD's Avatar
If anyone has pics of their Nittos that would be great to help me decide if they look ok. Please state which size they are too so I know which ones I'm looking at. Thnx!
Old May 3, 2004 | 02:21 PM
NA$TY-TA's Avatar
Im wondering this also....... im going to get another set of iForged wheels, but this time in 17's and ill be running 17x10's out back and i want to use a 315/35 also.
Kyle
Old May 3, 2004 | 07:10 PM
samz28's Avatar
are the 315's that much better in handling given 275 tires up top? or even 245-50-16's?
How does the staggered 275/315 affect the cars handling?
it seems like the wider tires in back might alter the geometry of handling kinda like swaybars? yes no maybe?
Old May 3, 2004 | 08:11 PM
Ferocity02's Avatar
Yes, you can put 315's onto a 10" wide wheel. Someone has put them on a 9.5" wide wheel just fine, looked kinda funny though. I think you will need to adjust the pressure in your tires since the sidewalls will bulge a little bit. What that pressure is I'm not sure. Nitto's are indeed slighly smaller widthwise than other tires due to differing measuring techniques.
A 315 drag radial will not provide that much added traction over a 275 drag radial. It's mostly for looks.
Old May 4, 2004 | 08:49 AM
Xsta Z 28's Avatar
Exclamation
I WILL REPEAT MYSELF!
Nitto says 10.5" minimum wheel width . . . direct from their website
I don't give a crap "what people have done . . " it is still wrong, still against manufacturer recommendations, and bottom line - DANGEROUS!
This one is closed.
