Front runner guys come (psi in tire seems to be a issue)
Old 09-21-2013, 10:28 AM
unioncarpenter84's Avatar
Default Front runner guys come (psi in tire seems to be a issue)
okay I got a set of racestars the 15x3.75 in the front with the federal 165/80/15 I got 50psi in them now but the max psi on the tire is 37psi what do u guys run in urs???
don't need a blow out seems like at 35 psi they look low on air
Old 09-21-2013, 12:31 PM
Someone gotta know what they run
Old 09-22-2013, 07:51 PM
anyone? have opinions
Old 09-22-2013, 08:34 PM
RobsZ28's Avatar
I run 40psi in mine with Racestar 15x3.75 with Nexen 165/80's. My tires say max of 36psi. Tires don't ride, look, or feel any different then they did at 35psi.
Old 09-22-2013, 09:13 PM
black and pink z28's Avatar
my mt sportman say 60psi in them
Old 09-22-2013, 09:17 PM
I'm worried bout a blow out I got 50 in them guess back down to 40
Old 09-22-2013, 09:19 PM
What did u pay for those sportmans
Old 09-22-2013, 11:07 PM
zbugger's Avatar
No matter what brand I used to always run 45 psi on my '77 Camaro. I ran 165/r-15's on 15 x 3.5 Cragar Superlite II's. Only once did I have a bubble on the tire, but that was from a manufacturer defect. Got that replaced quick before I had a blowout.
Old 09-23-2013, 08:53 AM
I don't remember right off the top of my head But I ordered the 8 ply They are rated for more weight
Old 09-23-2013, 05:22 PM
ya ill just have to keep a eye on it to make sure theres no bubble
Old 09-23-2013, 05:28 PM
X-Bomb Racing's Avatar
It depends on how much weight you put on them. If you look at that 37 psi on the sidewall it should say 37@x-amount of lbs. I have a v8 87 rx7 and i run 35 psi.
Old 09-23-2013, 08:51 PM
I think its 37psi at 1250lb
Old 09-23-2013, 08:55 PM
Now take what ever your front of your car weighs and do the math. At 37lbs it will carry 2500 with 2 tires. If your car weighs lets say 2000 lbs in the front then you would be safe around 34-35psi.
Quick Reply: Front runner guys come (psi in tire seems to be a issue)
