19x10 and 19x12 z06 wheels fit my camaro?
Super Hulk Smash
19x10 will fit without any problems in the front with the stock Z06 offset. The rears will fit as well, but you're going to have to use a BFH on the inner well, cut down the bump stops, and probably roll your fenders. But the offset is right... it's just a big *** wheel/tire.
What he said, gonna need a big BFH and completely remove bumpstops.
Also gonna have to get tubular Lca's and an adjustable panard bar. The rear must be centered perfectly. No room to spare.
Are they OEM wheels? If so yes on the front, the 19x10 front Z wheel had a 40 mm offset. What makes me think they're not OEM is you mentioned the rears are 19x12. The Z06's(Z07 package) that had 19x10 front wheels had 20x12 rears, and on cars that had a 19x12 rear there was a 18x9.5 front. I mention because some of the aftermarket Z06 wheels in a 19x10 size have a 79 mm offset to accommodate the stock rear fitment for base c6's. If the 19 has a 79 mm offset you might have problems up front as youd lose a bit over 1.5" of clearance on the inside, and the wheel would sit a bit over 1/2" more in the wheel well over a stock 17x9 wheel.
All I know is that they are 19x12 with 59 mm offset. Thats what is printed on the rear wheels. Might be aftermarket which is fine. My only issue is if the 19x12 with 59 offset will work. Im lowered and have aftermarket tubular control arms and aftermarket torque brace and panhard. Car has belltech lowering springs. Not the real low sportlines though. Thanks for the input guys.
Super Hulk Smash
325/30-19 or 335/30-19 would be my choice. You could even run a 345/30-19 and there are multiple tires in all sizes.
Up front would be a 275/40-18 or 285/40-18. The problem with staggered wheels is that the F-Body wasn't designed for them with the ABS system, so you have to run more upfront tire to make the diameter similar or live with the ABS INOP issue. If INOP is ok with you then 275/35 or 285/35 on 18s or 275/30 or 285/30 on 19s.
