best budget tires for dd/autox camaro
Hey all, I'm in the market for some new tires. My current rims are 17×8 with all weather/snow tires, not the best choice of tire for a 350 hp car..... I'm hoping to get some opinions on which tires to get for my new 18×8.5 rims, My camaro is daily drivin (will not be drivin in the snow) and it goes to the dragstrip/autox track roughly twice a year. I'm not looking for a drag/street radial, I'm looking for a tire that will last quite a while and won't loose traction every time I floor it. Thanks for the help
tire rack .com has plenty of choices. i wanted the closest to drag radial without actually being a drag radial so i chose G force 2's about $150 each. dont forget you want a high speed rating , cheers! look for rebates. edit nitto 555 street tire didnt come in my size 16" if i remember correctly
I got around 12k miles out of my old 555R drag radials which have a treadwear of 100. The regular 555 are 300. Expect to get at least 30k miles out of them I would say.
You can get a stickier tire at sacrifice of tread life.
The Nittos don't offer rebates as readily as the BFG's so you'll have to be patient to find them. The Nitto 17" 555's tend to be cheaper though ($125-$135/each from some sources). BFG currently offering $70 rebates on Comp2's. My BFG Comp 2's installed ran $555. Your individual driving habits and upkeep on the car probably play the largest role in how much tire life you get vs. which brand of comparable tire you end up buying.
If you're going to do a lot of cold weather driving (Nov-March in the upper half of the country) I might consider an all season tire with a better cold rating ( A/S ultra performance tire vs. the ultra performance summer). The Continental DW or DWS are good choices but will be more money than the BFG's and Nitto's. And I'm not sure how to differentiate "cold" from "snow" in those ratings. Kansas is probably borderline - you might be able to get by with a summer performance tire in the winter. I'd consider the BFG comp 2's, Nitto 555, Firestone Firehawk Wide Oval, some Sumitomo and Kuhmo's to be budget performance tires. Any one of those could work out fine for you. Your tires are larger than stock so will cost around 25% more in most brands. 18's aren't cheap vs. the 17" tires. In 18" only the Asian brands seem to offer an inexpensive price....everything else is approx >$700/set.
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
I'd be driving my car until the first snow/ice (when they put salt on the roads)which is usually in mid/late december . So I would be driving in 20-50 degree wether. I'm kinda leaning towards the g-force 2 because of the price, but the 555s seem to be a great choice too. Would 255 40 18 or 255 35 18 be the size I wanted?
Thanks for all your opinions and help guys.
Right now I'm rollin around on 17×8 rims with all season/weather 245 tires. I think this ought to be a good enough upgrade for now. Btw I bought the car a year ago and didn't have the money for new tires, so my dad bought me tires and said they had to be all weather/winter tires. That's why have them on my "race" car.
Forgot to mention this in my last post, but I could keep my old rims and tires for winter/ cold wether if the 555s or g-force 2's are terrible in the cold
Anything will be a step up from the all seasons but why not make a better purchase the first time around and be done with it?
What im telling you is spend your money wisely and hopefully make the right purchase the first time around. 8.5" wheels (255 tires) are simply too narrow for handling purposes with these cars (275/40/17s were the stock size for the WS6/SS cars, and even those are on the narrow side for best handling grip). Once you hit the track you will be quickly regretting the purchase, and wishing you went with wider wheels/tires that will provide way more grip. The serious guys are running 315/35/17 on all four corners (not saying you need to do this, but I would at least get a 9.5" wide wheel to run 275s or 285s.)
Edit: I'm going to be getting 17×11 zr1 rims all around for my car and the g-force tires don't come in 315s so I guess I'll be getting the Nitto 555's in 315 35 17
LS1Tech Platinum Sponsor
