Cray Scorpions 19x10.5 on 4th gen (how to)
This is for anybody who likes the Cray Scorpion wheel and wants to install them on your 4th gen. Here's what I did: I wanted to install 19x10.5 on all four corners, in order to do so, you will need to run wheel spacers. The spacers I chose are 20mm thick on the front and 25mm on the rear. These spacers are hub centric and wheel centric and they bolt onto your factory wheel studs. I found them on eBay for around $100. If you choose to run the 19x9 wheel on the front you shouldn't need spacers, the rears will need spacers, 12mm at minimum. Modifications may be required, such as, modifying the bump stops, rolling the fender lip, and shortening the factory wheel studs. Any spacer thinner than 20mm, you will need to replace your factory wheel studs for longer ones. Tire size I'm running now is 305/30ZR19. I hope this is helpful
Cray Hawks up Front Fitment?
I have a LS1 Trans Am with CTS-V 6 Piston Brembo Brakes up front. Can 18x9 Cray hawks fit? Im sure i may need to use a spacer. Does anyone know? I also plan on putting 18x10.5 Cray hawks on the rear. can both these go sizes on on my car. If Im not mistaken. The rear has a 3 inch lip and the front has a 2 inch lip. Please help me lol.
[QUOTE=Matthew Rountree;18926665]I have a LS1 Trans Am with CTS-V 6 Piston Brembo Brakes up front. Can 18x9 Cray hawks fit? Im sure i may need to use a spacer. Does anyone know? I also plan on putting 18x10.5 Cray hawks on the rear. can both these go sizes on on my car. If Im not mistaken. The rear has a 3 inch lip and the front has a 2 inch lip. Please help me lol.[/ r
I recall the manufacturer saying the wheels won't fit with aftermarket brakes. I have corvette c6 z51 brakes on my f body and the Crays fit with a spacers. My only suggestion would to buy one wheel from Americas tire or anybody who can order cray wheels. Install the wheel with no tire on it ( be careful not to scratch the wheel) if it doesn't fit you can still return it.
