Mickey Thompson ET Streets, street II's, or Street S/S?...
It's almost time for some new drag radials and I was wondering if anyone has tried the et street II or the et street S/S. If so, how are they as compared to the regular et streets?
I have Toyo TQ's right now, they do awesome at the track, but on the street I still can't hook on a 20-30 roll very good. I was going to get the et streets, but I am wondering if the other two does as good as the et streets. I won't be driving it in the rain, but if I do happen to get caught out unexpectedly, the other two look like they may get better wet traction.
So I would like any opinions on the et street II and street s/s vs the regular et streets or even they toyo tq's if you have one? I'll be pushing more power than I had on this setup.
Thanks,
Dave
Thanks,
Dave
When you say regular et street are you asking about the radial or the et street bias ply because they are different tires. If you're asking about the et street radial you need to specify radial. I've run the radials and street 2 radials, and I can tell you you're kind of asking an odd question. Here's why, they are the same compound. My 305/40/18 in my sig is not available in a radial 1 but is available in a radial 2. So how would one compare the two tires when they aren't available in the same sizes. If you must or choose to run a radial, the et street radial 1 or 2 is going to be about as sticky as you can get (with the exception of the radial pro but that only comes in a couple of sizes). I personally would not drive them in the rain, so I don't consider them DD friendly.
pretty sure the radial 1 & 2 are the same compound...the 2was released for bigger wheels.
I will be going from a toyo tq 315-35-17 to a 275-50-15 ET radial, so I can offer some feed back over the next couple weeks. I know not the same size but better then nothing I suppose.
Has anyone had any luck with running 295's on a 9" wheel? Pro's/Con's? I've read the stickies and know they don't recommend it, but I've seen a lot of people are doing it. Thanks
The street IIs aren't made in a stock size. They are a bit of a jump up in diameter. All 3 radials seem to be made from the r2 compound, and since the S/S appears to be a near identical tire to the II, you don't need to make that sacrifice to run a II. I am sort of confused about why MT is making new lines of tires, but not clear the real difference between them other then small visual differences in tread.
I ran the regular mt et st drs for a while. They were amazing at the track and still ok on the street BESIDES driving in the rain. I do not drive in the rain. Best 60' was a 1.5 with a ss3600 with those tires.
I don't go to track often anymore so last time I wanted a better street tire that is cheaper which of course comes with less 60' performance. I went with the toyo tq drs. I love them for street but never tracked them.
If I was going to go to a mostly track tire I would go hoosier dr. I have ran those and they are better than the mt dr imo.
If you drive in the rain I wouldn't wanna run any slicker than the toyo.
I have no idea why some companies try to reinvent the wheel. Maybe a rep at mt could enlighten us LOL
I may just go with the et street radials and be done with it, idk.
That's kind of what I was thinking too. I'm just not sure if they'll stick as good as the regular et street radial, but I'd like to try them. I was hoping to get some feedback on them but I guess they're still kind of new yet.
Anybody try the MT ET Street Radial S/S yet?
I had the Radial II 315/35R17 on my 92 vette a few years ago and was getting 60' in 1.6x, and that's with independent rear suspension. My only "complaint" was they REALLY didn't like standing water at 50+ MPH.
I just ordered a pair of Radial S/S 275/40R17 for the stock-for-now 01 TA. According to Mickey Thompson's web page, they're the same compound with the same contact patch and the same amount of void but redistributed for better resistance to hydroplaning.
I'm speaking only about 275 60 15 but will tell you what I'm hearing and have seen.
I've been running the et street radial 2 for the past 3 sets of tires. Once the ss came out it sounded promising.
Today I got to look at the et street ss, et street r, and et street radial pro side by side. The et steet ss looks great in the street friendly department now. But, if you look the ss has 3 grooves around the tire and they are very wide channels. The old et street 2 only had 2 and very narrow. There is NO way the contact patch is the same. Now, the et street r looks about the same but does not come in 275 60 15. If you need a street tire and the r comes in a size you can use I would choose that tire unless you will be in rain.
Over on yellowbullet the reults on the ss have been very mixed.
I went with the pro. My classes allow it and I have a set of c6 wheels for the street.
Pontiacerator
I'm in the middle of this dilemma as my TOYO's are about done. I'm talking about DD tires since I rarely go to the track anymore.
I found the TOYO's were good when new, but after awhile they weren't much better than stickier street tires. I do like the size and look, and I did get about 3 years out of them. Nittos did pretty well on the street, but they're just so small ...
I'd try these new Mickeys, but having used the original style at the strip for the most part, I've noticed they wallow pretty badly on the street. If the new tire has the same carcass, then it will behave similarly. Plus I can't imagine getting more than a year out of them.
Tough decision: another set of TOYO's, try the new Mickey's, go with a street tire, or street tires and old-style Mickeys for the strip (expensive)?
I have the 275/50/15 Mickey Thompson e.t. street radials on Race Star 15x10s. 3753R I think.
http://www.jegs.com/i/Mickey-Thompso...25#moreDetails
Are these being discontinued? Summit doesn't carry them.
http://www.summitracing.com/parts/mtt-3753r
They hook up great on the street, but they get bad mileage and they of course suck in the rain. What is out there in that size that I can use which will get more mileage, hook just as well, and be able to get me back safely in the event that I get stuck in the rain?
MTT-3451 Street S/S ?
http://www.jegs.com/i/Mickey-Thompso...49#moreDetails
The 3552's look like they would suck even worse in the rain: http://www.summitracing.com/parts/mtt-3552/overview/
They don't make a ET Street Radial II in 275/50/15
