Who has 335 tires on the back....?
Are the tires close to the LCA's...? How much room do you have in-between?
Do your tires rub the inner wells.....or the LCAs...?
In your opinion.....would 345's also work if I banged the inner wells more? Would the 345's also clear the LCAs...?
I'm gonna just put some 335 BFG Rivals with the 200 Treadwear rating. Should last a long time.
For good weather racing days/night:
My other rear set of 18 x 10.5 wheels which are an exact match for my 18 x 12.5's will get some 315 size M&T drag radials or the 315 Nitto drag radials that are on the new Dodge Charger that runs 9's.....
We'll see what happens.
I wish I could have finished....damn hurricane came and slammed us in South Florida.....never got to finish. Now I'm back in the damn Middle East, maybe till mid December.
But I do know what I'm doing....and I'll also be selling a simple kit so everyone can fit 335/345 tires on the back. Not a mini tub kit...there is absolutely no need to do a mini-tub kit. Just gonna provide the template on where to cut the inner wheel well wall, the 16 gauge custom steel plate to fit that cut-out pattern perfectly to be welded in place, and then you will need to hammer the upper inner wheel well areas so the tires won't rub up top. Very easy. Should be able to complete it all in 2-3 hours.
EDIT: I forgot to mention, offset LCAs are required to run 325/335/345 tires......
Too bad I couldn't get it done. My friend, a fabrication guy, is waiting for me so we can finish and make the kit.
The part on top of the bump stop needs cutting out first as it curves towards the tires.. I have 315's currently and that's where they're closest to. The rest of the tub is nice and soft and a BFH job.
But these 335's I have on my 18 x 12.5 rims.....YES, that entire area of three ridges sticking out and the entire bump stop are all getting cut out. Then the flat steel plate welded in. Thats it. I don't think I need to hammer anymore but won't know for sure until we slip them all the way on. But I think I can easily hammer another inch of clearance if I have to.
Looks like can also weld new bump stops brackets on the inside part next to the coil springs.
same here
Exactly my thinking when I looked at mine to run bigger than 315. I already have offset LCA's and they have a heap of clearance to the 315's, so 335's or even 345s shouldn't be an issue with the LCA's.
I've been looking at the three different offset LCAs that I found. maybe there are others....
What brand do you have? I need to get those also to make it all work. I want as much extra clearance as possible.
You would have to have two jacks with you....one to lift the car, so the tire would come off the ground, but also one to lift the axle and lower the axle to reposition where the bumpstop is....as you are trying to pull the tire off and put it on. You would have to slide the tire on as you dropped the car down towards the axle slowly as you lined up the studs to slide it on and angle the tire so the rim clears the bumpstop....everything in motion at the same time.. Pain in the *** with two people....but we stopped trying. Not sure we even could have pulled it off.
Founders with heim joints both ends. I think most of the lca brands are similar, but you need the heim joint style, and the offset spacers to go with it, the spacers are different lengths and fit on each side of the heim joints so it offset the lca inwards. The short spacer goes on the inside.
I wonder though...if you weld the bump stop back in.....will you be able to get a real wide tire off and back on.....if you got a flat on the side of the road. When we were fitting mine using a car lift at the dealership.....there was no way we could put my 335 tires off/on with a regular jack on the side of the road....the bump stop mount was in the way.
https://www.foundersperformance.com/...-arms-rod-rod/
But when I called to ask about them they said they do not offer offset LCAs for 93-02 F-Body.....they only offer the offset sleeves. Then you take those offset sleeves and install them into other LCAs.
I would think I could use the Founders LCAs and then just buy the offset sleeves from them...and they can be installed into the LCAs.
What does "hiem" mean?
LAUNCH......
Founders told me to buy their LCAs....then buy the UMI Offset Inserts and just install them on the Founders LCAs.
http://umiperformance.com/catalog/in...roducts_id=108
This is pretty good way to go too.
But what LCAs and inserts did you actually buy?
