20mm spacers....how long should the ARP studs be?
I don't think they will be long enough...I believe I bought 2.5" ARP's and running a 12.5mm Eibach spacer I have exactly ONE lug nut length left in the front. I bought Dorman OEM steel open ended lug nuts from Rock Auto. A 20mm spacer will be sketchy. I hope you are at least getting a hub centric spacer. I would think about 3-3.5" ones.
http://www.ebay.com/itm/2X-20mm-Hubc...818?rmvSB=true
Maybe we could help each other out with this issue. I just installed the 2.5" (100-7708) ARP studs and was trying to figure out the maximum spacer thickness I could run. With a 15.875 mm spacer, I have about 9 turns of the wheel nut. If following McGard's thread engagement rule of thumb, I need at least 8 turns (minimum thread engagement should equal diameter stud length) and therefore around 17 mm is as thick as you could go.
My question to you is do you have stock wheels? If so, could you tell me how many turns of the wheel nut (thread engagement) you have? The reason I ask is that TireRack recommends 6.5 turns of the wheel nut as a minimum for 12mm studs. I had around 5 but with OEWheels.
I also have OE Wheels. C5 deep dish. So I guess I will get 5 turns also.
So I guess I need 3" studs to get an additional 3-4 turns.
Hopefully someone can tell us how many turns they get with factory rims. I'd like to be able to whatever that number of turns is.
I use:
-20mm hub centric spacers
-2.5" 12x1.5 .509 knurl ARP wheels studs
-1.38" 12x1.5 Rocket Racing lug nuts
Based upon my calculations prior to purchase this was either directly the same as oem engagement or just a bit more.
All you need to do to figure it out is: add 20mm to length of stock stud... that # should be the same length as the ARP 2.5" stud or just a bit less
I use:
I use:
You pressed the studs out of the spacers, the studs that came with the spacers.....then just used the longer 2.5" ARP studs that you pressed into your factory hubs....correct?
I use:
OEM stud 1.63" (41.5mm)
https://www.summitracing.com/parts/r...t/model/camaro
ARP 2.5"(63.5mm)
https://www.summitracing.com/parts/a...7708/overview/
63.5-41.5=2mm to spare with 20mm spacer...
ARP 2.5"(63.5mm)
Mental math tells me 2.073" OEM minus the nose lenth of .326" get me to Dorman's length... since they don't have quick-start noses on their studs... nor does ARP's stud...which has no impact on thread engagement
...thank you for the micrometer measurements though. Appreciate your time
