16" Pro Stars
Old Jul 4, 2004 | 01:06 AM
Taphee6's Avatar
Default 16" Pro Stars
I picked up a set of 16" pro stars with et streets. How much grinding needs to be done with the 16's? Is it an easy fit???
Old Jul 4, 2004 | 09:09 AM
WildBills Toyota's Avatar
Should be no grinding with the 16 inch.
Old Jul 4, 2004 | 10:07 AM
Taphee6's Avatar
There has to be on a ws6. I already tried to mount them and they rub...
Old Jul 4, 2004 | 01:53 PM
C4VetteLS1's Avatar
then your somehow doing something wrong.
15's fit with minimal grinding
Old Jul 5, 2004 | 01:13 PM
SDB's Avatar
SDB
Weld Pro star in 16 are Xp series, the fit with no problems at all...
Old Jul 6, 2004 | 09:43 AM
Taphee6's Avatar
I dont think these are xp's. And I know I am not mounting a rim wrong. These rub on the caliper.
Old Jul 6, 2004 | 01:37 PM
SDB's Avatar
SDB
if they are not XP, then they are not 16 Inch, unless they are some weird anglia mount front skinnies....then they would not mount up right.
Old Jul 6, 2004 | 01:51 PM
Taphee6's Avatar
Nope, they are rear mount with ET streets on them. They are dated 2000. These do not directly fit a WS6. They are rubbing on the caliper.
Old Jul 8, 2004 | 12:42 PM
Bird_Of_Prey's Avatar
2000 was the only year they made a 16 inch prostar NON-XP! You're pretty lucky, there aren't many around. They are much lighter than the XP's. You need to grind the outer edge of the caliper a little bit. I did mine in about 5 minutes on each side with and iron file.
Old Jul 8, 2004 | 01:41 PM
Taphee6's Avatar
When you did yours did you have the WS6 calipers. I ground down one caliper last night quite a bit and it still rubs. I will work on it again tonight. But it just seems like it does not want to play nice in the sandbox...
Old Jul 8, 2004 | 02:59 PM
There are no difference in the rear brake calipers on any of the 98-02 Cars. Didn't matter if it was a V6 or WS6. I know you got your work done at HPA, if your in the north burbs, I can show you what I'm talking about.
Old Jul 8, 2004 | 03:20 PM
Taphee6's Avatar
HPA did some of the work. Damn it is a small world. If you can show me that would be great. Let me know what works for you...
Old Jul 8, 2004 | 10:28 PM
ironworker's Avatar
I also have weld prostars 16's and still needed to grind some. Not a whole lot, but just be sure your grinding on the part of the caliper that is causing the interference. I kept grinding more on the radius when it was actually the tab like thing thats sticks out that was causing me problems.
Old Jul 9, 2004 | 10:46 AM
CamaroCain's Avatar
wow, if i knew they were so special i would have kept mine, LOL
We had to grind pretty good on mine and still had to run spacers. Now i have convo pros and dont have to run spacers at all
Old Jul 9, 2004 | 11:57 AM
SDB's Avatar
SDB
are you guys using the XP series, or is their another 16 inch prostar that is not XP??? I have tons of room on mine.
SDB
Old Jul 9, 2004 | 02:48 PM
Larry's Avatar
Rub a marking pen on the outside of the caliber. Mount the wheel without nuts and rotate it by hand until you see exactly where it rubs. That's where you grind.
Don't grind anymore than necessary but remember when the calibers heat up they do expand and the clearance lessens.
Old Jul 9, 2004 | 10:35 PM
Taphee6's Avatar
Without lugs the wheel spins pretty good. When the lugs are on and tight the wheel rubs hard...
