New Member - camaro rim & tire question
New memeber here with 99 Camaro SS
looking to purchase the below set of rims:
Staggered 18x8.5 46mm & 19x10 65mm
Will these fit ? Best tire size combo?
Any other issues/concerns I should be looking at?
pretty sure those are factory corvette specs, so yes fronts should fit fine and rears will need a spacer. FWIW, I personally wouldn't ever put anything smaller than a 9" wide wheel on the front of these cars (unless it is a drag setup), since that is what some of them came with from the factory
Don't want to hijack the tread but will these rims fit a stock Z28. If so what tires are recommended? Good all around sport tires for daily driver with grip and cornering.
18x9.5
5x120.65
+56 offset
18x9.5
5x120.65
+56 offset
