How to guard against tire shop damage
What precautions do you take to guard against vehicle or wheel damage at tire/wheel shops?
I placed an online tire order today w/ Discount Tire to take advantage of the Memorial weekend promotion. Appointment for install is 7 days out.
I am strongly considering bringing my 98 WS6 wheels to the shop in the back of my truck. Seems that eliminates some opportunities for damage. Could be the shop would take great care of my vehicle and wheels, but do not have any, recent transaction history w/ this shop.
LS1Tech Administrator
Received 1,794 Likes
I never take the entire car to a shop just for tires, unless it's a daily driver - but even then I still wouldn't bring in a 4th gen F-body unless you know for sure that the tech/shop is familiar with proper lift points for these cars. Most damaged fender tabs are the result of improper lifting at various shops, no need to take the risk when there isn't any work to be done on the actual car itself (such as simple tire mounting).
Yes only take just the wheels if you can. If you absolutely cannot, if they want to put it on the lift, SHOW THEM the tabs under the front fender where they can not lift on. Demand they lift on the front frame rails (at least that's where I always jack from). Or they can do it 1 wheel at a time (unlikely). I've seen my local shop use 3 floor jacks and just leave cars up on them (2 up front, 1 for the rear axle) and it makes me cringe, if one were to lose pressure. Also they must use a hand torque wrench, none of this impact-gun-torque-rod silliness.
However, I didn't see chevygirl mention anywhere that she had WS6 wheels. Perhaps that information was posted in another thread.
How have your chrome WS6 replicas held up and what kind of use have they endured. Just curious as I considered purchasing a set new ~2007. IIRC, there used to be a manufacturer or vendor for them in Michigan back then called Lakeshore, AAA, or some variation thereof.
2. Ask if they have a touchless tire machine
3. Ask for the most experienced tech and reiterated the cost of replacing wheel or wheels if damage occurs.
I am going off topic a bit now that I have the info I sought.
Yes, good memory on the vendor in MI. It was in fact AAA Rims (later changed their name to Lakeshore Wheel and Tire, but they were still AAA when I bought them). They were just a vendor though, these were imported reproduction new wheels. AAA/LWT also used to sell some refurbished original wheels, but the ones I bought were definitely new aftermarket.
FWIW, I thought the car looked much better with the chrome version. The polished clear coat OEM version looked too cloudy for my taste, so I was quite happy with the swap.
I have the ZR1 gm chrome wheels on my 99 camaro and I think they are discontinued.
I'm pretty certain that there are still a couple of sources which sell reproduction C4 ZR1 wheels in chrome, but I think they are only available in the C4 Corvette sizing (17x9.5", 56mm offset). The C4 sizing fits just fine on a 4th gen F-body, but original F-body sizing for the SS/WS6/Firehawk wheels (regardless of finish) was actually 17x9", 50mm offset. Both wheel sizes can fit the same 275/40/17 tire size without issue, but the 9.5" wide C4 version were originally intended to accommodate a 285/40/17 rear tire size on the non-Z51 models (Z51 models received a square 275/40/17 setup, same as an SS/WS6 car, even on the 9.5" wheels).
Chrome C4 ZR1 wheels are definitely still available, just not from SLP. Plenty of aftermarket sources, but I'm not sure if you can still get them in the original 17x9", 50mm offset sizing. They are usually reproduced in the 17x9.5", 56mm offset C4 sizing (which will fit on a 4th gen F-body, with stock tire size, without issues).
It's a legit concern bringing your vehicle to a place that employs a high number of low experience techs. The alternative is easy. Find a shop that works on exotics. They have a higher labor rate, but you certainly won't end up with a damaged vehicle or damaged wheels. It'll cost more than average, but you're looking for service that is higher than average.
Joe
Joe
