Options for restoring these Torq Thrust 2's
I bought these polished aluminum TT2's back around 2008, probably have 65,000 miles on them at this point. I use Meguiar's aluminum wheel cleaner and scrub with a wheel brush with every wash but haven't polished them in years. I tried using Mother's polish and Powerball but it looks like it did absolutely nothing. Would a professional be able to restore these? What kind of shop do I search for?
Pontiacerator
Once they get milky and spotted like that there's no polish that can do it. Post #9 in this thread tells you how to do it. It's some serious work!
https://ls1tech.com/forums/wheels-ti...e-somehow.html
have you thought about having them powdercoated, there is alot of nice color options out there.
The following 2 users liked this post by Kjduvall:
B52bombardier1 (01-05-2024), wannafbody (01-02-2024)
Save the manuals!
If you look for places that do rim straightening, they will have the other services like this. I'm sure there are more.
First thing that came up in a Google search was this place: https://www.nwwheelandtire.com/services/
The following users liked this post:
wssix99 (12-12-2023)
Maybe you don't want to do the labor but I wonder if you could try polishing the wheels by pretending it's new paint.
I help at a body shop a couple days a week. On the resto's with base coat clear coat paint we start with 1000 grit wet. This gets the orange peel out. Then 1500 grit wet. This gets the 1000 sand scratches out. The sanding is done by hand. Then 3000 wet. After that a polish and buff with power tools.
Wouldn't be too tough with the wheel off the car.
Just a thought.
Just a thought.
buy some different shaped wool buffing wheels that you can chuck up in a drill from harbor freight and some either compound or aluminum polish and try concentrating on one spot for a minute and see if it takes some one that oxidation out..if not 1000 grit sand paper and step up to 1500 then try polishing again with the drill and aluminum polish...guarantee they will look near brand new again.
They said the oxidation was in the coating, not the aluminum after trying to restore a small spot on the wheel.
Sounds better than $260/ wheel for a new set. I'll give it a shot, thanks!
