OEM Z06 offset
Old Feb 21, 2005 | 08:27 PM
Zymosis's Avatar
Default OEM Z06 offset
After reading the 'does it fit' sticky, I was looking at OEM Z06 rims, and I thought I read somewhere that the 18x10.5's on the back have a +65mm, is this true?
And if so, would it even work with F-body without spacers?
Old Feb 21, 2005 | 11:53 PM
Raise's Avatar
i wouldnt
Old Feb 22, 2005 | 08:12 AM
Xsta Z 28's Avatar
Base Corvette 18" x 9.5" are 63 mm and the Z06 18" x 10.5" are noted to be 58 mm.
A 65 mm wheel will not fit our cars . . .
Old Feb 22, 2005 | 08:16 AM
Oskar_Z28's Avatar
What is the stock offset on the F-body wheels?
I am looking at getting some that have 56 mm offset. Currently I have Enkei V-1s that have too much offset (not sure how much), but my tires rub the fenders. This is with only 275/40/17 tires.
Old Feb 22, 2005 | 01:22 PM
Xsta Z 28's Avatar
OEM wheels for the SS had a 56 mm offset. Too much offset IMHO . . . .
Old Feb 23, 2005 | 12:38 AM
Zymosis's Avatar
I was pretty sure a 65 wouldnt fit, and I dont know why i can't find the Z06's with correct offset.
Old Feb 23, 2005 | 02:31 AM
cowboys z28's Avatar
there are some on ebay
17 x 9.5 + 54mm & 18 x 10.5 + 58mm
Old Feb 23, 2005 | 02:12 PM
Xsta Z 28's Avatar
Because they have never been made with the correct offest for the F-Car. People are just making them fit, with the BFH mod and wheel spacers.
If you can find the 53 mm offset they are the best fit.
Old Feb 23, 2005 | 11:36 PM
UJSLOST's Avatar
I have had TWO sets of OEM SPEEDLINE Z06 wheels on my car and both fit fine. NO spacers !! I had 295/35-18 first and then 305/35-18 the second time.
The second set, I had to hammer a "little". Not much. I also have Sportlines and adj. panhard bar. Hope this helps.
