Drag Radial in the rain...
Old Mar 15, 2005 | 12:45 AM
DeViOuSwOn's Avatar
Default Drag Radial in the rain...
Was looking at the 555R's or the MT ET Street radials for the summer. The only thing I am debating is using them in the rain. Is this something I should be worried about. I can not see it being that bad, it's not like I drive in ponds or puddles. If the roads are wet I usually drive like a grandmother anyway.
Thanks
TJ
Old Mar 15, 2005 | 08:42 AM
JayLS1-327's Avatar
Neither is ideal for the rain, but of the two the Nitto's would be better.
Old Mar 15, 2005 | 08:55 AM
GM Muscle's Avatar
I've never had a problem with my Nittos in the rain. There are horror stories out there but if you take it easy and don't ask for trouble you should be fine. If you routinley have to drive on the highway you might want to consider another tire, seems most of the mishaps have been from hydroplaning at higher speeds. As for the M/T, I'm going to be running those this year and my car will not see wet pavement with those. Running M/Ts in the rain is asking for to much trouble IMO.
Old Mar 15, 2005 | 09:53 AM
DeViOuSwOn's Avatar
Yea, I do make the occasional drive on the highway but if I am running DR's, I have a lil more brains to take it to a normal speed. Thanks guys, any more guys run DR's in the rain.
TJ
Thanks again.
Old Mar 15, 2005 | 09:55 AM
DeViOuSwOn's Avatar
Oh and the MT's I was refering to were the Street Radials not the ET Street Slicks...
TJ
Old Mar 15, 2005 | 10:51 AM
01black's Avatar
I have run nitto 555R's all year, I have even tested thier wet traction limitations and I was suprised at them, the only time the were un predictable was going around a turn...just a little bit of gas would kick the rear end around easy...
Old Mar 15, 2005 | 10:55 AM
DopeFedZ's Avatar
As long as you are careful in the rain you should be okay.
Old Mar 15, 2005 | 11:07 AM
DeViOuSwOn's Avatar
Yea I figure I will be ok, thanks guys!
TJ
Old Mar 15, 2005 | 11:56 AM
12stones's Avatar
The mt's will be a no no in the rain, but just take it easy and use caution in the rain then the nittos will be fine!
Old Mar 15, 2005 | 04:26 PM
Blue Meanie's Avatar
I can only comment on the nittos, but personally I was shocked by their wet weather performance. They have been better than any "regular" street tire I have owned. Including the supposedly all weather BFG KDWS I have. And we get some pretty good Monsoon conditions here. The Nitto's grip in the wet with a 4 inch wide bald patch in the middle. Of course, I drive like an 80 year old grandma in the rain.
Old Mar 15, 2005 | 05:07 PM
GM Muscle's Avatar
I noticed that too when going from the stock RSAs. It takes some effort to break them loose in the rain.
Old Mar 15, 2005 | 05:11 PM
DeViOuSwOn's Avatar
Thanks guys for the insightful comments and opinions...
TJ
Old Mar 15, 2005 | 05:12 PM
Martingale's Avatar
I have Nittos on my daily driver Mustang. I drive in the rain. To me the car feels a little lighter and a little spooky when it's raining really hard but when it's just raining lightly it's fine. Of course 5.0 Mustangs don't feel as stable as F-bodies in the rain in the first place, so that has a lot to do with it. Different car totally.
Old Mar 15, 2005 | 05:32 PM
BriancWS6's Avatar
Compared to the Yokahama ES100 street tires I have on the car now, the Nittos aren't as good in the rain. Use common sense and you'll be fine however, but it doesn't take any effort to break them loose, I found it happened more times than not. Good luck!!!!
Old Mar 16, 2005 | 01:27 PM
Sotiri's Avatar
So Nittos are better in the rain... is that the final answer? It is pretty scary on the highway with the M/T dr's.
Old Mar 17, 2005 | 09:57 AM
skimms98's Avatar
You couldn't pay me to drive M/T's in the rain. On the other hand I keep my Nittos on both my cars until the first snow shows up here in VA. Then it's back to regular treads for the winter. I'm already wringing my hands waiting to put the Nittos back on this year !
Old Mar 17, 2005 | 12:01 PM
Got Me SOM's Avatar
I've driven my Nitto's in the rain and they arent bad, I wouldn't even think about using the M/T's. I would save them for track use and Saturday night racing only.
Old Mar 25, 2005 | 11:17 AM
Sotiri's Avatar
If the Nitto's are a LITTLE better in the rain than the M/Ts, then i am going to stick with the M/Ts. They hook like crazy!!
Old Mar 25, 2005 | 11:40 AM
sb427f-car's Avatar
SSU'S Vice Mod
How much would you drive them in the rain anyways? Are you just concerned about them doing in a pinch, like say a light drizzel or a quick summer t-storm?? Or is this you'r daily driver?
Old Mar 25, 2005 | 01:41 PM
Sotiri's Avatar
Daily driver ( all kinds of rain conditions)... looking to stay moving with the traffic on the highway (ie: 60 mph) Are Nitto's (555R) good enough?
