Where to get open end lug nuts?!?!?!
Old Jul 26, 2005 | 02:01 PM
Captain InsaneO's Avatar
Default Where to get open end lug nuts?!?!?!
I can't believe how simple this is yet no one has them.
I am looking for a 12 mm x 1.5 2" in length, Conical lug nuts, in chrome for my Fikse rims.
I have seen them on e-bay so I know they make them. I should have bought them, but 50 bux for a set of 20 seemed high.
Any ideas who can get them, or who makes them? Any sponsors carry them?!?
TIA.
Old Jul 26, 2005 | 02:03 PM
Chaotic Firebird's Avatar
www.summitracing.com
Old Jul 26, 2005 | 03:35 PM
I called them. They don't carry anything like that.
Old Jul 27, 2005 | 05:22 PM
This licks *****.
Old Jul 27, 2005 | 10:26 PM
Derek98z's Avatar
Have you called Fikse to see where they recommend?
Old Jul 27, 2005 | 11:32 PM
Its not a matter of what lug nut will fit. I can use a standard 12mm x 1.5 acron style conical lug nut. I am needing to find a 12mm x 1.5 conical lug nut open end thats 2"-2.5" in length cause I am going to use ARP 2.5" wheel studs.
Old Jul 27, 2005 | 11:52 PM
prelude00782's Avatar
Why on earth would you want open lugs. 80% of the stripped wheel bolts I've seen were due to open lugs letting dirt, grime, brake dust, and all other sorts of crap in there. If you insist on them for some odd reason any auto parts shop should have them in that size.
Old Jul 27, 2005 | 11:56 PM
Long studs will cause a closed end lug nut to bottom out before it will secure the rim to the hub. I have to run longer studs for the Weld Draglites (skinnies).
Old Jul 28, 2005 | 10:11 AM
Derek98z's Avatar
Do they not make a long enough closed end style? I've seen some really long closed end ones.
