3rd gen f-body wheel fitment help!
I realize this may not be the best forum for this question but, your help and insight would be appreciated.
I'm going to order 17X10's and 17X8's for my 90 camaro rag. Just want to make sure my measurements for BS are correct. Rears are 5 1/2 bs and fronts are 4 3/4. Gonna run Nitto 315/35/17 DR's on the rear and 275/40/17 NT555's in the front. Thank you for your help
You'll probably need a hammer for the front lower inner fenderwell near the LCA bracket.
Don't drive the car till you visually inspect that area for clearance.
Originally Posted by 1998TA__1991RS
i need help too, but im going with 18x10 and 18x9 with 275 and 295's
you had to run the wheel spacers correct?
I've got a 2" bolt on spacer.
http://www.ls2.com/forums/showthread...hreadid=233339
here is a link of some pics where I put 17 x 9's on my 92 camaro
used 2" adapter/spacer for front and 1.5" adapter/spacer for rear
(like said above if you have 98+ rearend no need for spacers on rear)
