Does Anyone Run Skinnes And Meats On Every Day Driver
Originally Posted by gillbot
Matter of fact, I have yet to PERSONALLY hear about a lateral failure of a skinny wheel other than fron an accident or outright abuse.
I had always thought that in this age of political correctness and paranoid fear of lawsuits, wheel manufacturers would never knowingly sell a weak wheel to the buying public, the majority of whom uses them on the street where they're most prone to failure because of lateral loading that they were never intended for. Knowing this necessarily isn't the case, at least I would never run any wheels of this type on my car on the street. The last thing I want to do is plow someone down sliding on a rim that came apart just because I wanted to look cool.
Originally Posted by slow3hoe2
so basically i have the best of both worlds. i drive anywhere with no problem. then drive to the track....release about 1.5 psi of air out of the rears, then pull some wheelies. its not too bad.
Do you do this without mods? Just curiois cause you dont have any listed
Ok good question.... How come skinnies cant take the occassional pothole, but they can take the weight of the front of the car slamming back down from a wheelie? Im not talking about just bearly lifting the wheels off, i mean scraping the bumper and watching the clouds.
you are a *** and you would sound more knowlegable if you didnt even speak.
i love when someone that hasnt experienced something is gonna come on here and tell us how it is.
Originally Posted by ArcticZ28
How exactly are you going to be aware of some idiot slamming on their brakes in front of you on the highway, or someone pulling out in front of you? No chance in hell you're gonna escape either one of those situations safely with skinnies up front (or, I should say, your chances of avoiding it are greatly decreased). Skinnies were made with a purpose... for the track. I would never sacrifice such a huge point of safety for the 'cool' look.
AS I SAID, I have not PERSONALLY seen a failure. Never said it COULD NOT HAPPEN. Read before you reply. I'm not condoning the daily use of them, I used to run them on mine 24/7, did I say you should... NO. Do I know they are not DOT rated, YES. ANY wheel can fail if XX or XX or XX happens, so freaking what. As long as you are aware SOMETHING MIGHT happen, do what you want. Just don't try and get all high and mighty on me because they are illegal, like most of the cars here are not illegally modded anyhow.
#32
And would it matter if you had OEM wheels and tires if you got cut off? Not really, that's why it's called an ACCIDENT.
#33
I see no ignorance in my reply.
As I CLEARLY stated:
Something might happen when you change anything, just don't try and pull the whole "they are illegal" statement because that's a load of ****. 99% of the cars on this site are illegally modified in some way.
#34
finally.....running skinnies is sooo tight never had more fun!!!!! thanks guys car llooks sooo mean now i would recomend it for any real street racer!! ohh yes and i took the sway bar off to ...not to much differnt but it doesnt matter anyway i wont be autocrossing anytime soon!!!!
![](http://i21.photobucket.com/albums/b266/tondss/DSC00546.jpg)
![](http://i21.photobucket.com/albums/b266/tondss/DSC00549.jpg)
#36
ive trying to find some threads that discuss this clearly and its kinda hit and miss and a little confusing for me so i will jsut ask.. To run skinnies up front what will have to be done to the car? are there any type that doesnt require grinding and longer studs? thanks for any information.
--Matt
--Matt
#37
ok well it does require grinding but its really no big deal everyone makes it out to be! AS long as you do a good grind you wont have to worry!! you dont need to change the wheel studs there fine just get the... crager clossed in 12-1.5mm<<pretty sure do a search...good luck!
#39
wow those other wheels that dont require grinding are
in my (opion)...go with the real stuf!! prostars or draglites they save you the money!! save like 500 more dollars just to grind for 20 minites.....
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
#40
wellllll back on topic...i recently put pro stars on my camaro and i daily drive it like its my job. drive out to wauseon (40 minutes from here) a couple times a week and back with no problem, and my car doesnt handle worse at all..and ive had people slam on the brakes in front of me and it really doesnt stop that bad..IMO
