tire presure
Old Feb 19, 2006 | 09:51 PM
blackngoldt/a's Avatar
Default tire presure
what psi should i have in my 245/50/16 tires? right now its at 30 psi, is that ok??
Old Feb 19, 2006 | 09:59 PM
ssmaro's Avatar
Yeah that's perfect, just don't go over that.
Old Mar 1, 2007 | 12:28 PM
01WS6JACKLE's Avatar
my tirer are 275 49 zr17 what shuld the tire presure be on them,ive been runing about 40psi.is this to much
Old Mar 3, 2007 | 03:32 PM
Blue LS1's Avatar
WAY too much! Quick go outside, and take 10lbs of air out of each tire!!!!
Old Mar 3, 2007 | 03:35 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I run 34-36lbs all around.
Old Mar 3, 2007 | 03:36 PM
NHRAMAN's Avatar
Exclamation
30 psi is too low..for a driver.
Old Mar 3, 2007 | 04:42 PM
DuronClocker's Avatar
Ideally you should chalk your tires and drive around for a few minutes, park it and see how evenly worn away the chalk is Of course this takes time, but its the best way to figure out exactly what pressure you should be running. I'm too lazy to do that. I usually aim around 32psi. Anywhere from 30-35 is good for the street.
Old Mar 3, 2007 | 04:52 PM
Blue LS1's Avatar
I agree. From reading a few threads on tire pressure, I find most live in this range, with the majority in the area of 30-32.
