Are Mods required for 315 TTII's on the rear?
For those of you with TTII's, if I am putting 17x11 TTII's with 315/35/17's on the rear, will I have to use the BFH mod or roll my fender lip? I don't really want to have to do any of this.
Thanks
Thanks
More than likely, mine usually hit on highway driving where there are dips, or if I have people in the backseat. An adjustable panhard rod may help some, but more than likely you will have too. I have an eibach pro kit by the way, if your not lowered then I don't think it will hit. Hope this helps.
-John
-John
Even at stock ride height you may have to do some BFH. You will not have to roll the outer fender lip unless your car is lowered. It also depends on what tires you choose. If you have Nittos you may not have any rubbing, but if you go with Goodyear GS-D3s you probably will. At stock ride height, I had to do some BFH for my GS-D3s to fit. It wasn't really a big deal. You can't really mess anything up doing it.
Originally Posted by BlackHawk T/A
If you are at stock ride height no. There is no way mine would ever have a clearance problem...
BTW, your car looks great. Any more full length pics?
To answer the original question, you may be able to get away without any mods since my guess is you have a TA by your user name. You'll just need a smaller 315. If your car is lowered the odds of not having to do any mod is slim IMHO.
Budnik Hammers with BFG drag radials in rear on mine,No BFH,No rolling fenders,No shaving bump stops,No rubbing.But my car is a factory height Firehawk with the Bilstein suspension.Which I guess is lower than a stock T/A.
Originally Posted by jst
lplease explain "rolling the lip".Will this crack the paint?
*edit* Here's a pic (don't mind the dirt or the loose jam nuts on the LCAs, I was adjusting things ) of the driver's side. Front of the car on the left
*another edit* That was done to help fit 15x10 wheels with 28x11.5" tires. Hammering might not have to be done for the 17x11s
