what size tires?
Old Aug 3, 2006 | 10:23 AM
gapp94vert's Avatar
Default what size tires?
hey guys im trying to find out what size tires fit zo6 wheels i was gonna get 2654017 for the fronts and 2953518 for the rear but my local tire shop wants almost 850 dollars for them mounted and balanced i was wondering if other sizes fit those wheels the fronts arent a bad price its the rears that are killing me almost 250 a tire
thanks for the info
Old Aug 3, 2006 | 10:52 AM
RollTideTA's Avatar
If you can post the size (diameter x width, for example: 17x9.5 & 18x10.5) of your wheels, I can tell you what the ideal sizes are and what the smallest size that you could run without modifying your speedometer.
Old Aug 3, 2006 | 11:09 AM
Xsta Z 28's Avatar
18" diameter tires are expensive . . . . Kuhmo Exsta MX is a reasonably priced tire.
Old Aug 3, 2006 | 01:06 PM
gapp94vert's Avatar
yeah they are 17x9.5 and 18x10.5 and what would be the ideal sizes for them?
Old Aug 3, 2006 | 01:21 PM
gapp94vert's Avatar
hey im sorry the size of the wheels are17x8.5 and18x9.5 thanks again
Old Aug 3, 2006 | 02:14 PM
RollTideTA's Avatar
You sure thats the size? It matters alot ... really it does!
For the front 17x8.5 the ideal size would be 245/45/17.
For the rear 18x9.5 the ideal size would be a 275/35/18.
I'd recommend BF Goodrich G-Force Sport tires. Mainly because of their long wear rating of 340 AA and good price. The fronts would only be $111 each and the rears would be $166 each if you ordered from tire rack.
You need to be absolutely sure what size your wheels are before you get any tires, because an inch makes a huge difference. The original tire sizes you put in the first post of this thread would be more for a 17x9.5 and 18x10.5. I just dont want u to order the wrong thing
Old Aug 3, 2006 | 02:41 PM
gapp94vert's Avatar
yeah im sure thats the size thanks for the info my local tire shop is being stupid they dont want to return those other tires that i ordered so i guess im kinda stuck paying 800 dollars for tires yeah it sux but thanks for the info
Old Aug 3, 2006 | 03:19 PM
RollTideTA's Avatar
That really sux then... because the smallest wheel that is recommended by most manufacturers for a 265/40/17 tire is 9".... where yours are 8.5"....
AND the smallest wheel that is recommended for a 295/35/18 is 10"... where yours are 9.5". You need to bring that up as a safety concern and see if they might let you swap them for the correct sizes at least.
And, If you haven't paid them anything yet... just tell them to get over it because you want the correct size tires.
Old Aug 3, 2006 | 04:43 PM
gapp94vert's Avatar
tru tru thats good info i could use that its too bad that it goes under my dads account which is a charge account so they could just charge us but if they arent reccomended for that wheel then thay would have to take them back i will try that thanks man
