tire wear question
Old Aug 12, 2006 | 03:02 PM
slimcracka's Avatar
Default tire wear question
ok im on my second set of bfg drags (315 35 17) on my zr1s and the last pair and this pair seem to wear faster on the inside than on the middle or outside...i just changed my LCA a couple months ago after i changed the tires. is this a known problem with a f-body or what....
Old Aug 12, 2006 | 03:08 PM
ls1muscle's Avatar
try getting an alignment
Old Aug 12, 2006 | 03:22 PM
slimcracka's Avatar
the rearend is solid and i got an alignment when i lowered it...if it was an alignment issue then the outside of one side would be worn along with the inside of the other like the rearend was crooked(sp)..
Old Aug 12, 2006 | 03:27 PM
EvilBLK02TA's Avatar
Check your tire pressure, if they are over inflated it will wear out faster in the middle of tire and if its under inflated, the outter edge and sidewall will wear faster.... just my .02
Old Aug 12, 2006 | 04:30 PM
slimcracka's Avatar
i got them on 20psi hot.. is that too little?
Old Aug 12, 2006 | 04:50 PM
SSilverSSurfer's Avatar
yea it is
Old Aug 14, 2006 | 02:52 AM
CaptUSA's Avatar
I wouldn't run that low. Give her another 10 pounds. Enjoy longer lasting tires, and longer lasting gas tanks.
Old Aug 14, 2006 | 12:04 PM
i run 30 cold, and the wear is even all the way across
Old Aug 17, 2006 | 07:45 PM
slimcracka's Avatar
anyone else wanna add...
Old Aug 19, 2006 | 03:46 PM
slimcracka's Avatar
t t t
Old Aug 20, 2006 | 06:40 PM
98hardtopZ's Avatar
the sides of my front tires are worn alot more than the middle but that could be because i take turns fast and hard...my back are at 32psi and even all the way across...
