Nitto RIIs
I have an A4 with a little over 400hp and a SY3500. I presently have Kumhos and am thinking of going to the Nittos 555RIIs. I have basically no traction off the line now, so I thought the RIIs might do a little better.
The problem is, I drive the car on long trips occasionally, and I don't want to give up the handling. Because of that I have been also looking at the Goodyears. Some say the dry traction is just as good, but the wet weather and handling is better. (The price is pretty close)
I also read in my search, that the Nittos only hook good after they're "warmed up", which you don't always have time to do if you know what I mean.
Am I making a mistake with the Nittos? Should I just go with a full thread tire like the GSD3s?
Thanks
Also, they may call it a "drag radial" but I don't agree. It is basically a soft compound radial (street tire). On the street it will act like a real good radial, but if you heat them up it can stick like a drag tire.
Compared to the other drag radials, it is the best on the street but the worst with traction. Compared to other street tires, it is worse on the street (but I like them, there are no problems running them), but the best in terms of traction. I consider it a middle of the road tire that is decent in all areas. The things they don't do well are hard cornering (sidewall flex) and rain when the tread is low.
But they are no Mickey Thompson.
I love to take the car to the mountains for some spirited driving, and use every on ramp as an excuse to test my driving skills. I rarely visit the drag strip (80 miles away) but need great straight line traction VERY often.
I may have to consider the Goodyears after all
I wouldn't really expect any of these tires to ride too smooth; after all, with a 35 aspect ratio and performance suspension, mine doesn't ride too smooth over rough roads now.
I realize there are very few tires that will provide everything in one package, so my priorties are;
Great dry traction
Great handling
I'm not as concerned with;
Great wet weather handling (I don't want dangerous though!!)
Long life
Also how are you only chirping the tires? With your mods you should be annihilating them. At least I do, with a similar car, on the 555R's. I can light em up just hitting the gas.
I tend to forget I live in CO and others have a lot more power than me lol. I should have specified that.
As for wet traction, I've never had a problem with that either. I'm also very careful driving in the rain, regardless of the tires I have on but I have never had the car come out from under me unexpectedly.
You also have to keep in mind your 400hp isnt going to be easy to tame. A GS-D3 isnt going to give you anymore traction than a drag radial at those power levels. Regardless of tire choice you're going to have to sacrifice something. For ME, the RII is an excellent tire choice, for you you're probably going to encounter traction problems unless you run a stickier tire than both. At that point you're going to sacrifice handling.
The 295 Kumhos were a decent tire before my latest round of mods. I had prefected a launch technique of loading against the brake, then "driving" off of the line and easing in hard on the throttle to control spin. With the latest mods, however, I just can't keep from loosing traction. The 0-60mph times with my G-tech pro, are worse now than they were with less power.
I may have to give the RIIs a try. If I don't like them, I guess you will see them in the For Sale section
Thanks
Thanks
