To fit Prostars How much grinding?
How much is it safe to grind cuz on the fronts the wheels dont fit and I grinded alot already and still rubs on it. Is ther a caliper that I can get with no grinding? maybe the LT1's?
From what I have seen you can fit them on LT1 calipers, But on ls1 calipers there is LOTS of grinding to do!!! Just be sure to keep test fitting your wheels so you dont go to far!
I ground (front & rear) mine til they fit, with no spacers. They have been that way for two years now, and havent had any problems. But, it is ALOT of grinding that has to be done...
yea, thax guys, what happened is that Im running 15x4.5 cuz they didnt have more of 3.5 and apparently that company is broke so thats the last ones I found. Im using 5/16 mr gasket and still rubs the damn wheel. Ill get longer studs and grind a lil more I guess
Originally Posted by 00TurboT/A
If you run them grind them. Spacers are are like a hot girl with a STD. You know you want it but you know you shouldn't and it WILL catch up with you if you do.
Ok Im done but what a crap have all that damn dust all over, good that I had glasses, hat, mask, gloves, but still my eyes are a lil red any special doctor advice around here?
Originally Posted by Christian8A
what size are you running ?
Yea, thanx man, nice car by the way I have the same setup as you then, 15x8's and 15x4 but I had to do a lil more grind than a 3.5 but is done finally, Ill post pics tomorrow
Thanx everybody
Thanx everybody
