Run Flat Tires - Good in Theory - BUT . . .
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
Here's my story . . .
On the STS-V it comes standard with Pirelli Run Flat tires . . . sounds neat right? No need to worry if you get a flat just drive to the nearest service center . . . sure
NOT!
So anyway I get a drill bit of all things dead center in the tread section of the rear tire of the STS . . . Well fortunately I have another vehicle to drive, and carry the damaged tire to the local tire shop nearst my work. . . .
First stop, Just Tires (Elmhurst) "I need a tire patched" The guy looks at it and states "Nope!" . . . . "Nope what?" . . . "We can't fix it here need to go to our Westmont store that is certified to fix run flats" . . . "Can't you take it there?" "NOPE!" . . . So I leave pissed off.
Go to Westmont. 5 miles away . . . guess what . . . they can't do it either!!!!!
Go back to work. . . . hop on internet, to find store . . .
NTB, says can't fix run flats must buy new tire . . . $431 plus m&b . . . .
Discount Tire, same story . . . .
Find a Just Tires 14 miles away that will fix the tire . . . Need to leave it there for 1.5 hours and pick up later.
So, if the Cadi was my only car I was basically F&%^@#! . . . since I would have driven so far on the run flat I still would had to buy a new tire, that had to be special ordered . . .
Nice stupid design! Great in theory but useless in reality . . . Since the Cadi is stuck in the garage with only 3 tires, beacuse when you get run flats GM does not give you a jack or a spare tire! . . . .
Oh and I have missed over 2 hours of work! Rant off.
NOT!
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Sorry to hear about your problem Xsta. To tell you the truth, I think run flat tires are a waste of money. The manufactures do say that they must be replaced if punctured and not repaired and they weigh a ton. If I ever purchase a vehicle with run flat tires, the first dollar I would spend on it would be to replace the run flats. Don't want the extra weight or the issues that you are experiencing getting it repaired or replaced. Just my opinion.
I have fixed several runflats in the past and will do so in the future. They do not want them patched since you can not tell what damage has been done to the side wall. There is nothing special about patching a run-flat tire. it looks the same on the inside. I patch only with the understanding of the customer about the liability. Even the tire says DO NOT PATCH, or most of the ones I read.
Runflats are great in theory, but when it comes to ride they ride harsh and do weigh a ton.
sorry to hear about your pain about the tires. They are a real pain in the A$$ to gett off the wheels also.
LS1Tech Co-Founder
run-flats SUCK. You should see how big of a PITA they are to mount/dismount. When putting them on a $700 (each) wheel, it makes you cringe to see how stubborn those tires are to get on a wheel. A can of fix-a-flat and a small lighter powered air compressor is enough run flat for me.
AGREED! If I bought a new C6 or Z06, before I even drove it off the dealer lot I would have (and install) some great sticky tires, either on cool aftermarket wheels, or on the stockers (IF they even make stock sized NON runflats).
Hey Xsta,
I noticed your nice line up in cars, if you don't mind me asking, what do you do? I am actually from Medinah/Roselle and know the Just Tires in Elmhurst. You ever go to the cruise nights there on Wednesdays during the summer?
BTW, sorry to hear about the tire.
hey better they tell u they cant do it there. they cant because there scared they will **** up the rim. then this post of urs would have been alot worse lol. low pro run flats suck to mount
Sorry to hear that. But as a current discount tire employee that has fixed run flats, i am a little bummed to hear you say that Discount would not do that for you. All discount tire locations should be able to fix them, as long as the repair is in the safe zone. Hope you dont pick up and more foreign objects.
