325 50 r15 mt et
325 50 r15 mt et
hey i just got these from summit racing. have them on 15x10 weld racing wheel. is there anyone running them and if so did you have to shave your brakes down to fit inside this rim. also were you able to run them on a 1" drop.
i got 5.5 they stick out more than i like about 2 in past the fender, wish i would have went with 7.5, also if i change the height with hp tuners will it fix my abs light. it came on because my new tires are about 2in taller than the stock
Originally Posted by NOSJNKY
Thanks and me too!!
Do you happen to have any shots of your car from the side? It looks awesome, I just gto rid of my cragars and are running weld's now and would liek to run a 325 on mine. Thanks in advance.
Thanks. Heres the Only full side shot I have ,the pavement isnt even so it looks higher than it really is on the drivers side
you didnt happen to be at the capital city corvette club show at irmo HS back in the fall did you? if so BAD *** CAR
The springs are stock all the way around. The front uses the "Iron block 408" lowering mod! The back is stock with the isolators removed.
1998TA-Thanks,yeah that was me at the Irmo show. those guys put on a great show!
Bacardi-I did roll the lips, although I never had an issue on the street they did rub a little at the track BEFORE I rolled them. Now there is plenty of room...well maybe not plenty!
