anyone have fitting issuses????
Old Jan 19, 2007 | 06:22 PM
408Maro's Avatar
Default anyone have fitting issuses????
just curious to see if anyone else that has z06 wheels from tomzwheels had any fiting issuses?i bought 17x9.5 for the front and those fit ok and also have 18x10.5 and the wheel hit the bumpstop.anyone else have this problem?what did you guys do i had to buy spacers and of course with that it made the studs even shorter so i couldnt use the lugs that comes with the rims so i had to use temporary ones.anyone know where i can get longer chrome lugs?and with the spacer will it be ok or should i take out the bumpstop? thanks guys
Old Jan 20, 2007 | 07:49 AM
408Maro's Avatar
anybody?????
Old Jan 20, 2007 | 08:08 AM
InsaneAuto86's Avatar
I took out the bumpstops (i am running the same size rims) and havnt noticed any changes. But I also dont know the purpose of bumpstops... lol
Old Jan 20, 2007 | 10:52 AM
1BadTA13's Avatar
did you jack the car up by the axle or the frame???...i just got some too and if you jack it up by the frame they will hit....i also bought 7/32 spacers for the back...
Old Jan 20, 2007 | 01:53 PM
Xsta Z 28's Avatar
Must support the rear axle to install. That is normal.
Old Jan 20, 2007 | 08:48 PM
TomZwheels's Avatar
That would be correct. When you jack by the frame the axles drop down to a position they will never be in while driving. Put the weight back on the axles.
Old Jan 21, 2007 | 10:18 AM
408Maro's Avatar
ok so lift it by the pumpkin then and ill be good?do i still need the spacers?im using 5/16 spacers and also will i need to do any other mods? thanks guys
Old Jan 22, 2007 | 08:10 AM
Xsta Z 28's Avatar
Spacers are not required. Some minor inner wheel well massaging may be needed.
Old Jan 22, 2007 | 08:17 AM
HeapaShifter's Avatar
I cut my bumpstops out. I also hammered the wheel well some. I didn't like the idea of running spacers. My rear wheels are 17 x 11's.
Old Jan 22, 2007 | 08:28 AM
Xsta Z 28's Avatar
No reason to cut the bumpstop off . . . that will lead to destruction of your shocks.
Old Jan 22, 2007 | 09:39 AM
The reason I cut the bumpstops out is because I always put my car on a two-post lift. When the suspension extends they would hit. The bumpstops themselves were already trimmed way down from when I put the lowering springs on anyways.
Old Jan 22, 2007 | 04:00 PM
408Maro's Avatar
thanks guys i ended up after everything taking off the spacers and it seems ok so far,where would i need to hit at with the hammer if i need to?
Old Jan 22, 2007 | 10:06 PM
michaelg589's Avatar
I dont like the idea of having to jack up the car by the rearend. If the wheels hit the bumpstops thats NOT GOOD. What if you were to hit a bad bump (accidentally of course) and the suspension moved enough for the wheel to come down and hit the bumpstop? Your wheel would be fucked and your tire would potentially be shredded. Maybe thats not much of a concern for those who hardly drive their F-body, but for those who are like me and daily drive theirs,, its definately a good idea to make sure the wheel has plenty of room. I have 18x10.5 C^s in the rear of my car. They hit the bummpstops with the car jack up by the subframe. I installed 5/16" spacers. Not only did it bring the wheel out enough to clear the bumpstop, but the wheel is also not sunken in. which is the case for most corvette wheels on f-bodies.
Old Jan 23, 2007 | 12:30 AM
phrozen755's Avatar
how much did everyone pay for their spacers? and where did you go to get them?
Old Jan 23, 2007 | 08:27 AM
Xsta Z 28's Avatar
Originally Posted by michaelg589
I dont like the idea of having to jack up the car by the rearend. If the wheels hit the bumpstops thats NOT GOOD. What if you were to hit a bad bump (accidentally of course) and the suspension moved enough for the wheel to come down and hit the bumpstop? . . . . .
Unless you peform a Dukes of Hazzard jump with your car, that event will NEVER occur.
But IF you cut off your bump stop, and hit a big enough dip/bump the spring will compress too far, forcing the piston of the shock too far, destoy the shock, and depending on you offset of your wheel, smash the tire into the quarter panel and bending the body work. . . .
So either trim the side of the bumpstop of leave it a alone.
Old Jan 23, 2007 | 09:10 AM
sick240's Avatar
i removed mine and have had no problem with it.
Old Jan 24, 2007 | 07:06 PM
408Maro's Avatar
michealg589 did you have to get longer studs or lugs? thats the same spacer size i was using thats why im curious. and i payed $2.19 for mine but i work at a tire shop to
Old Jan 24, 2007 | 08:14 PM
I did not use longer studs or lugs. I was told I did not need them and that 5/16" spacers were the largest you could go with stock studs.
And Xsta Z28, Maybe I'm ****, but i dont like the idea that my wheel could, under any circumstances hit my car. I like things to fit right.
Old Jan 25, 2007 | 10:20 AM
408Maro's Avatar
hmm thats cutting it pretty close bro because those lugs arent really catching that much on my studs with my spacers
Old Jan 25, 2007 | 10:47 AM
they seemed ok on mine.
