Unusual Problem Inside..
Old Jan 31, 2007 | 10:45 AM
ZFan88's Avatar
Default Unusual Problem Inside..
So I traded my TTIIs with a buddy that had SS ZR1, both 17s, the ZR1s 17x9...but I'm sure most of you know that. I have 275 drag radials and I went to put them on the car. He had an LS1 and I have an LT1 so I'm not sure if that has anything to do with it. One wheel went on fine, but the other didn't mount flush for some reason. So I tightend the lugs, but couldn't get one lug on..on the wheel that wasn't flush, so I left it off. I just lowered the car so I need an alignment anyways, but it was way off. I was going to pull the wheels off and swap sides to see if that might be a problem. I take off all the lugs, but the wheels won't come off! I check to see if something was holding them on, but nothing. They won't budge. And yes, all the lugs are off with the rear end in the air. I'm not a small guy, and I was yanking on these things. Ever heard of this before??
Old Jan 31, 2007 | 10:48 AM
Xsta Z 28's Avatar
The center hubs of LT1 cars are a tad bigger that LS1 cars, you need to slightly ream out the center hole of the wheel.
Very common problem.
Old Jan 31, 2007 | 10:50 AM
ZFan88's Avatar
Wouldn't that be seen while putting the wheel on the first time? It went on real easy, I don't know why it won't come off though. And the fronts fit just fine
Old Jan 31, 2007 | 06:54 PM
bigman's Avatar
a sledge hammer to the tires will take care of the wheel coming off. And you might need to enlarge the center bore of the wheel.
Old Jan 31, 2007 | 07:58 PM
ZFan88's Avatar
Ya, I even kicked the hell out of it from underneath the car and it's still not coming off lol
Old Jan 31, 2007 | 08:21 PM
iroc85blu's Avatar
use a 4x4 or large pry bar or sledge to inside of tire. That should get it off. But put one lug back on first so it doesnt eat the pavement when it flies off. I work for a tire shop and i use the sledge almost everyday. Some wheels are very corroded and there really is no other way.
Old Jan 31, 2007 | 09:00 PM
UAZ28SS's Avatar
At least you know they'll never get stolen...
Old Feb 1, 2007 | 12:18 AM
ZFan88's Avatar
lol i thought about that. sucks if i get a flat though. at least they're flush now, just permanent
