11 inch rear wheels
Old Apr 17, 2007 | 11:15 AM
playboy245's Avatar
Default 11 inch rear wheels
I have a 99 z28 and i;m thinking of putting 11 inch zr1's on the rear, what size tires will that be and is there any modifications i have to do for them to fit.?? All help is greatly appreciated..
Old Apr 17, 2007 | 11:24 AM
chupr0kabra's Avatar
Search this section of the forum.
-Mike
Old Apr 17, 2007 | 01:17 PM
TXws6's Avatar
315/35/17. If you get the Nitto555DR for example, they should fit up with no problems. If you go with a wider 315 like the GSD3's then you will need to do a little BFH for sure.
Old Apr 17, 2007 | 01:47 PM
TheLS1Kid's Avatar
+1
But dont be scared of BFH, its not bad at all.
Old Apr 19, 2007 | 08:35 AM
playboy245's Avatar
what rim would the 315's fit on, thr ss 10 spokes, the c5 zo6, or the zr1's
Old Apr 19, 2007 | 09:02 AM
LS69TA's Avatar
17x11 ZR1s, The SS wheels are only 17x9, and the Z06 wheels are only 17x9.5s. You need a 10.5"+ wheel.
Old Apr 19, 2007 | 12:13 PM
Z28LS1camaroguy's Avatar
[QUOTE=TXws6]315/35/17. If you get the Nitto555DR for example, they should fit up with no problems.[QUOTE]
That I will soon find out then, im gonna be runnin black ZR1s with Nitto 555 315s out back and was wondering about fitment.
Old Apr 20, 2007 | 11:20 AM
Azrael's Avatar
Each car has its own character but like someone already said there should be no fitment issues with that combo. We have run Nitto 555Rs on both 17X11 ZR1s and 17X10.5 TTMs (on the SS) and no issues and we have not touched the car (with the BFH).
Old Apr 21, 2007 | 12:14 AM
bamalt1's Avatar
I have 17x11s on my Z28 running a 315/35 BFG T/A KD with no problems. The previous owner used the BFH a little but he had a bad back so it didn't do a lot of good. I have no problems at all.
Old Apr 21, 2007 | 03:21 PM
The93z's Avatar
I would put 315s on them. Will have to take the bump stop off
Old Apr 21, 2007 | 06:18 PM
No, you won't. Just learn to jack the back of the car up by the differential case and you'll be fine.
-Mike
