Which Bogarts look better?
Old Jun 24, 2007 | 09:49 PM
LSGunZ28's Avatar
Default Which Bogarts look better?
Drag stars or D10s? which look better on a 2002 Pewter Z28? the car has a 1.5" drop and I have on snowflakes as a DD. this will be drag only rim BTW (the bogarts).
Old Jun 25, 2007 | 04:42 AM
Brasshead's Avatar
Here are Drag Stars on my Black "SS" with a 1" drop.
Old Jun 25, 2007 | 05:16 AM
01RedZ28's Avatar
Brasshead very nice those have my vote.
Old Jun 25, 2007 | 09:18 AM
Ling_650vette's Avatar
Thats a tough one...I like the look of the D10s better tho.
If you go on the SJM Manufacturing page, they've got a pic of a pewter car w/ the bolted D10s just so you can get an idea.
Old Jun 25, 2007 | 10:55 AM
Nine Ball's Avatar
LS1Tech Co-Founder
If you are going to pay for premium racing wheels, at least get some that stand out. Bolted R/T wheels:
Old Jun 25, 2007 | 11:14 AM
SLowETz's Avatar
+1 ..... what Tony said-
Bolted R/T Drags
Old Jun 25, 2007 | 11:36 AM
H/C/I Stang's Avatar
D10s
Though the bolted RTs look nice as well
Old Jun 25, 2007 | 01:11 PM
JGKadell's Avatar
Welded Floyds
Old Jun 25, 2007 | 01:48 PM
LSGunZ28's Avatar
I lik ethe dragstars the best, and prostars and D10s second. I just dont know how they would look on pewter, thats all.
Old Jun 25, 2007 | 03:04 PM
Not the same image I was referring to earlier, but here's an idea of D10s w/ Pewter
And Cragers car with Bogarts (I swear, WTF cant his SS be used to show? )
More pics found here
Old Jun 25, 2007 | 03:41 PM
Tim_WS6's Avatar
SLowETz, your car is badass!
Old Jun 25, 2007 | 03:50 PM
LSGunZ28's Avatar
I went from the D10s to the dragstars.
I lik ethem better and everyone seems to have D10s, especially on the pewter cars
Old Jun 25, 2007 | 03:52 PM
Ericbigmac83's Avatar
I'd "settle" for any of them. I do like the d10's though
Old Jun 25, 2007 | 03:54 PM
carado1984's Avatar
So i guess with the bogarts BS and design of the rim being exactly correct for our cars, you guys can get away with 325/50s lowered??????????
because i cant decide if i should or shouldnt lower it because of problems with fitting those tires and also true duals..
i figure if i lower the car and get 325s i can fit true duals without bumping do to the extra space the 28" tires created..
BTW i vote for BOLTED R/T's
Old Jun 25, 2007 | 04:05 PM
LSGunZ28's Avatar
I have
15X4 fronts
15X9.75 rears
Tell me what tires I should use (drag only) , when I DD the car it will have the snowflakes on.
Im thinkin' Hoosier bias ply skinnys in front and Hoosier slicks in the rear
tell me the size I should run please I think I Was told 26X10.5s would fit on the rear rim.
and I dunno what PSI the Norm for Slicks in the rear.
when I was using M/T et streets I had 18psi ( launching @ 5500RPM and bogging still) and Nittos I has 12 psi (launching @ 3700rpm).
Thanks
Old Jun 25, 2007 | 04:06 PM
LSGunZ28's Avatar
Oh and til how good is a 10inch wide or 10.5 inch wide slick til, like will it support me til the single digit club or just into the 10s?
Old Jun 25, 2007 | 04:50 PM
JGKadell's Avatar
There are people running single digits on Drag Radials. Your suspension plays a big part in the hooking. If it is for race only wheels, I would go with bias ply tires as they are MUCH lighter. For skinnies up front you will be looking at 10-13 pounds per tire for bias ply and 20-25 for radials.
I don't know if you know that he abs will be out of whack if you run different size tires (overall diameter) in the front and rear.
Typically you would want a 26" tall tire on front.
Old Jun 25, 2007 | 06:50 PM
LSGunZ28's Avatar
Yeah Im running 26"s rear and I think 26 in front. Bias ply both of em, since its drag only.
well Im gonna run slicks, Im just saying will the width of a 9.75" be a problem in running single digits. My car is roughly 3400 lbs without me in it.
Thank 3pt SFCs, Moser 12 bolt and chrome moly Torque arm in adding extra weight. though I have an aluminum FW, Aluminum DS, removed AIR and will install a K member in a few months when I do H/C
