NEED HELP?28x12.5x15 ET Streets
Looks good but it rubs the rear quarter panel. My rear is narrowed 3' on each side. I do not wanna go 26' diameter because they only can go 11.5 not wide enough tread.
Originally Posted by lethal93ta
did you roll the fender lip at all?
ya the part that stick straight in about an inch, I think its lakewood that makes a tool that you bolt fast to the axle and roll it around
I didnt roll the fenders on mine I only have 26 11.5 15s on mine and with the 9 inch the back of the car sits a little higher so I have room, if you want to see my rear adn how it fits just go to http://www.streetlethal.net just click on moser on the left hand side or new car pics to see pics of the car with the wheels on there.
what for wheels do you have? why do you need a big tire? if you get a 15x10 with a 4 inch back space it would be the same as mine, I have 15x10s with 5 inch back space.
they do, stock back space for a 10 inch wheel is 7.5 so you take 3 off really you want a 4.5 back space just centerline is in even numbers, heres a prostar in 4.5 back space
http://store.summitracing.com/egnsea...5&autoview=sku
I wish they had 26' tire that had a 10.5' tread width. I guess I am going to do some riggin cuz I gotta make this work. Thanks for your help. I'll let ya know how it goes.
run eather MT et streets that are 26 11.5 or 275 50 15 thats 10 inch tread width 26 inch tall tire
the tires on mine are 26 11.5 15 thats 9.8 tread width and 12 inch over all, thats still a healthy tire
Originally Posted by Camaro396
like he said, the M/T 26x11.5-15 tires only have a 9.8 tread with, however Hoosier makes their DOT tire in a 26x11.5-15 size, with a true 10" tread width.
if you buy adj. lca's you might as well buy the off-set ones so you wont have to worry about a wide tire rubbing your control arm. with that being said if your rear is narrowed 3" and you want a 10" rim, get a 4.5" or 5" backspace. i would shoot for a 5" backspace if it is available with whatever rims you decide to go with. that way they wont stick out at all. if they tuck in further there will be no need to roll the lip. tuck them in as far as you can without hitting the lca's.
he needs 4-4.5 to keep the wheel where it was, with 5 hes going to be getting close to the tire rubbing the inner fender with as wide of a tire as he wants mines narrowed 2 inches each side and I have 15x10s 5 inch back spacing with 26 11.5s theres about 2 inches of room behind there with his being narrowed 3 inches that makes it and inch space and he wants 10.5 tread tire that another inch in width that would make the tire rub the inner fender. your going to hit the inner fender before you hit the lower control arms.
with only a 4" backspace, the rim wil stick out too much. a 4.5" backspace will put the tire in the correct location. i told him in a pm that he would have to "massage" the inner wheel well behind the tire directly above the lca. there are plenty of people on here with 1/2" to 1" of extra backspacing to tuck the tire in more. i beat the crap out of my inner fenders and my tire would rub the lca first. it takes a little more work like cutting the bump stops and more hammering but it works. and looks sweet too. if you post this in the drag racing section you will get much more feedback. oh and i forgot to mention, an adj. panhard bar helps center the tires from side to side because stock doesnt always have them even.
Alright you guys are gonna laugh about what we did to make it work.
Just thought you might be curious... First we loosened the panhard bar a lil bit then I spent about an hour grinding the SHIAT out of the brake caliper. Of course we beat the **** out of the inner fender well BFH mod. Grinding the brake caliper down made us not have to use the spacer. Which pushed the wheel in Quarter inch. Well My paps (aka old school) (aka Professional rigger) got called in he said watch we will drill a small hole in bottom of fender lip get some thick safety wire tighten it to another bolt into the frame of the inside of the car and it will pull the lip back so it don't rub and we don't have to cut it.. Well shiat worked and it looks good don't even notice it unless you get under car and look at the bolt holding in the safety wire in. We drove it on bumpyass road and took it on the highway No rubbing yet.. Thanks for the help fellas.!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
