ET streets or ET drags???
Old Oct 8, 2007 | 02:41 AM
mcamarols1's Avatar
Default ET streets or ET drags???
soon ill b in the market for some drag rims and tires, ill b going with 15x3.5 & *15x10* (edit)
now do i get the ET streets or the ET drags? what are the benifits of each? also what size tire for each rim?
i already have a 12bolt w/3.73s, and its an m6
*edit*
Old Oct 8, 2007 | 08:45 AM
SREETRACEGUY's Avatar
well it is all your personal preferance i'm goin with the 15x8 on a 26x11.5x15 MT drag radial if you goto jegs.com go to wheels and tires then to details of the tire you want it tells you MT's suggested rim size
Old Oct 8, 2007 | 11:37 AM
Camaro396's Avatar
either or. i actually think the et streets hook harder.
Old Oct 8, 2007 | 01:02 PM
caged02's Avatar
If you are planning on driving around alot on the street then get the drag radials. ET Streets drive like **** on the street, *** end always feels kind of loose.
Old Oct 8, 2007 | 01:55 PM
Camaro396's Avatar
i daily drive on et streets it doesnt bother me.
Old Oct 8, 2007 | 09:13 PM
mcamarols1's Avatar
i wouldve have thought that the slicks would hook better, any one else have any experience?
Old Oct 8, 2007 | 09:49 PM
Camaro396's Avatar
i dunno ive had both a set of et drags and et streets on my car, and i think the et streets hooked harder on the street. the et drags were kinda old though so that coulda been it.
Old Oct 10, 2007 | 07:34 AM
trigger1's Avatar
^That is it. New for new the et drag (bias ply tire) is going to out hook the ET street (bias ply non radial tire).
To the orginal poster, being that you are a stick car I would suggest either the ET street (non radial) or the et drag. Stick cars and radials are a weird combination. Some have made it work, many have not.
Old Oct 13, 2007 | 10:09 AM
XX11SECZXX's Avatar
ive got et streets (non radial) on my thirdgen just for the track. driving it out there it isnt bad unless you have them at about 15psi or less. i run them at 20 to get out there and air them down when i run.
Old Jun 22, 2008 | 06:51 PM
Vetal's Avatar
Trying to make the same choice. Which slick will hook better - ET Drag or ET Street? Surface is not very sticky at my track, if that matters
Old Jun 24, 2008 | 05:59 PM
Vetal's Avatar
Guys, what will hook better on M6 - ET Street or ET Drag (both M5 compound) ?
Old Jun 24, 2008 | 06:36 PM
themadspoon's Avatar
I just got a set of 26x10.50x16 et street (bias ply) they hook very well on the street, and as far as the drivability of them on the street i have had them up to a decent speed and with no front sway bar i haven't had a problem.
Old Jun 25, 2008 | 02:03 AM
bigsticksupra's Avatar
if both of them are the same compound (M5), what is the difference between the ET DRAG and ET STREET? I doubt those few thin *** lines in the ET STREET will really make that big of a difference in traction. I have the 28x10.5S ET DRAG.. the only reason y i got the ET DRAG was for the S sidewall
Old Jun 25, 2008 | 12:32 PM
Vetal's Avatar
hope someone will clarify the difference between these
