17x11 rears
Old Oct 17, 2007 | 05:53 PM
buddha845's Avatar
Default 17x11 rears
do i need to pound out the wheel wells to avoid rubbing on a stock fbody?
Old Oct 17, 2007 | 06:00 PM
99zee's Avatar
Stock ride height, maybe not. You won't know for sure until you put the wheel/tire on there. Seems like everybody is a little different. Post pictures when they are on
Old Oct 17, 2007 | 07:28 PM
TTSSZ's Avatar
Whats the offset?
Old Oct 17, 2007 | 08:18 PM
buddha845's Avatar
Offset: +50 mm(17x11) straight from the site
Old Oct 17, 2007 | 09:40 PM
Arachnotron's Avatar
Depends on what size and brand of tires you have. On my car I did have to do some BFH. I have goodyear GSD3s 315/35 which run wide compared to some others.
Old Oct 17, 2007 | 09:44 PM
spazzyfry123's Avatar
I ran those wheels on my SS with 315's and didn't have to do anything at all with stock height. But then again, I ran **** tires (Sumitomo). But like ^ said, something like the GS-D3's that read 315 but really measure something like 335...You're gonna need to do some bangin'.
Old Oct 17, 2007 | 11:49 PM
TXws6's Avatar
what size/brand of tire are you going to run?
Old Oct 18, 2007 | 05:56 PM
buddha845's Avatar
a reasonably (as reasonable as it gets ) priced 315, no particular brand in mind tho
Old Oct 18, 2007 | 06:01 PM
NVR KNO's Avatar
I run 17x11s on stock ride height and have no problem. I run both 315 Nittos and 315 BFGs, which from what Ive heard are the widest 315 tire you can get, dont know if its true though. Havent had a problem yet....
Old Oct 18, 2007 | 06:03 PM
NVR KNO's Avatar
If you want resonable, go with the Nitto. Its not a true 315 so it should help with not hitting anything.... Not bad price either. I cant remember retail price because I get mine for cost, so....
Old Oct 18, 2007 | 07:17 PM
motownZ's Avatar
is it better for the strip to go with 11's in the rear or like a weld wheel with lots of meat, sorry im new to this
Old Oct 18, 2007 | 07:50 PM
neeshSS's Avatar
I'm stock suspension with 17X11 TTII's with sumitomohomos. i would highly suggest getting an adjustable panhard bar for sure. it is definitely worth it. I didn't have to hit anything, but i did grind my bumpstops a tad.
Old Oct 18, 2007 | 08:38 PM
Mike00ss's Avatar
I ran goodyear GSD3s 315s on stock ride height and have no problem on my Zr1's 17X11.
Not sure what the offset is.
Old Oct 18, 2007 | 11:18 PM
buddha845's Avatar
thanks for the input
Old Oct 19, 2007 | 12:18 AM
transam5.7lt1's Avatar
I had some trouble a while ago fitting my C6 wheels on the back... and mine are only 18x9.5 !!!!!
Old Oct 19, 2007 | 09:07 AM
TX RED's Avatar
I AM ON MY SEC SET OF 17x11 IF YOU LIVE AROUND POTHOLES I WOULD SUGGEST THAT YOU ROLL THE FENDER LIP
Old Oct 19, 2007 | 09:45 AM
COOKIE MONSTER's Avatar
I had no problems with my nitto 555rs 135/35/17
Old Oct 19, 2007 | 12:30 PM
Hennytime's Avatar
Originally Posted by 1BDTRAM
I had no problems with my nitto 555rs 315/35/17
ditto
Old Oct 19, 2007 | 04:26 PM
TheLS1Kid's Avatar
I run 17x11 ZR1's with a +50mm offset wrapped in 315/35-17 GS-D3's.
I am at stock ride height and I had to BFH my fender wells. It not hard though. After you are done just spray some rubberized undercoating in the wheel wells and you wont even be able to tell they were beaten.
Good luck.
Old Oct 21, 2007 | 11:32 PM
UGOTWS6D's Avatar
I just put on 17x11 TTII's with 315 nitto 555r tires....no rubbing issues at stock height, i'd say i have about a 1/2" of space between the tire and inner fender well. I'm very happy with the nitto's...good looking tread design, nice ride and no noise from what i can tell so far. I got 4 tires from ws6store for like ~$730 shipped (2-315 555r's and 2-275 nitto 555r II for the front).
