Wheel studs???
Old Jun 16, 2003 | 02:55 PM
MYBLKSS's Avatar
Default Wheel studs???
Do you need to run ARP wheel studs or something equal to that in order to run welds/ET streets?
Old Jun 17, 2003 | 11:20 AM
MYBLKSS's Avatar
Default Re: Wheel studs???
ttt
Old Jun 18, 2003 | 09:48 PM
LOnSLO's Avatar
Definitely.
Old Jun 22, 2003 | 12:11 PM
Fast SS on TNT's Avatar
Under no circumstance should you run a stock GM stud. Do the ARP's, and never have to worry about snapping them bad boys off.
Old Jun 22, 2003 | 12:40 PM
Smoke_Ford's Avatar
How much are a set of those?
Old Jun 23, 2003 | 11:11 AM
Xsta Z 28's Avatar
about $14 bucks for a pack of 5. I have two sets brand new never used for sale if you want them. E-mail me.
Andy
Old Jun 24, 2003 | 06:08 AM
2001SS#3013's Avatar
Does anyone have the part number from lets say Jegs so I can order some?
Old Jun 24, 2003 | 07:18 AM
MYBLKSS's Avatar
Should I still run them even if I am running 16 inch oem rim with et Streets? Are the ARP studs the same length and pitch as the stock bolts, I just want to be able to throw my stock 17's back on with no problems like the lug nut covers not being able to be put back on.
Old Jun 24, 2003 | 07:20 AM
MYBLKSS's Avatar
Xsta Z 28 how much do you want for the studs if they are the same exact fit as whats on the car now?
Old Jun 24, 2003 | 09:41 AM
Xsta Z 28's Avatar
$25 shipped UPS to your door.
ARP Lug Studs
Replace your weak factory wheel studs with ARP’s heat-treated 8740 chrome moly wheel studs. These are a much-needed replacement for any car engaged in track or drag racing competition. They have a tensile strength of 190,000 psi and are able to easily handle the tremendous acceleration shock loads (shear) and lateral forces (elongation) found in racing. The studs are sold in packs of 5 and are cadmium plated for extra durability. Nuts not included
ARP Wheel Studs, 12mm X 1.5, 2.5" length
They use the same lug nuts as stock. They are longer than stock, but by how much I have no idea. I was going to use them on my car since I was planning to run some spacers for my old wheels, but I broke down and bought new wheels instead.
Old Jun 24, 2003 | 01:14 PM
MYBLKSS's Avatar
I think I am going to hold off for now. I really don't want them to stick out on my stock ZR-1's, but thanks anyway
