315/60/15??
Old Nov 24, 2007 | 10:20 PM
Fast_94_Z's Avatar
Default 315/60/15??
is anyone running these on a lowered car? ive done a search and couldnt find much. i plan on mini tubing the car, relocation the control arms, and using coilovers out back to make room. probablly going to go with a 15x12 rim with 5 1/2" backspacing. just looking to see if anyone has these on a lowered car.
Old Nov 25, 2007 | 08:09 PM
phoenix's Avatar
i plan on running that sixe tire on my car lowered. i just got the tubs and cage done should have the car back next week and when i get the tires i will post pics but may be a while. i want to tuck those monsters
Old Nov 25, 2007 | 11:49 PM
Fast_94_Z's Avatar
same. do you till have your trunk floor and suspension in or did u go with a custom cage and 4 link setup
Old Nov 26, 2007 | 03:08 PM
phoenix's Avatar
i have a custom cage and tubs, the guy who did the work wanted to move the shock so he could really do a tube but i wanted it to be stock suspension. so everything is in the stock location and the tub ends where the shock mounts to the body
Old Nov 26, 2007 | 11:46 PM
Fast_94_Z's Avatar
can you post pics? im gunna relocate my lca's and im going to a coilover so that i have more room since im going to be running a 15x12 rim on a 325/50/15 or 315/60/15. i dont plan on racing in any classes. its just a hobby for me so im making a go fast show car.
Old Nov 27, 2007 | 08:36 AM
phoenix's Avatar
well i was running the 325's with out the tubs on just used a hammer to make it fit, the only problem i was having was on turns it would tub (i have a spool) for most people the main reason for the tubs is to fix a 30"tall tire without looking like a 4x4 if your going to move the shock and go with a coil over i would put the m&h 390 DR
Old Nov 27, 2007 | 06:48 PM
Fast_94_Z's Avatar
well i plan on having a pretty extreme drop on my car similar to the w2w 93. so i want my wheels tucked pretty good. im not running a full tub either just a mini tub so i can keep my interior plastic in.
Old Nov 27, 2007 | 07:00 PM
phoenix's Avatar
well you can do a pretty deep mini tub get rid of the spring and the stock shock location runa coil over and more the LCA fit a nice fat tire no problem with the car on the ground well hurry upa nd do it i want to see!
Old Nov 27, 2007 | 11:15 PM
Fast_94_Z's Avatar
my suspension should be here next week and then time to order the body parts and wheels and tires. i have a lot of work ahead. a complete color change including painting the underneath of the car, new motor, new trans, rear end, and so forth. can u please post a pic of your cage i need to get some ideas for mine.
