c6 z06 wheels
I am looking at chrome c6 z06 replica 18" all the way around with 10.5" width in the back (unless it comes wider). I would like to get a 315 street drag tire on the back. I believe it comes in 58mm offset?
My question is, will this be able to just put right on? rubbing issue? any modification necessary? Also, what is the wieght of these wheels? and would there be a difference in performance/traction when going from a 17" to a 18" wheel?
Thanks...
Thanks...
Generally a taller profile provides more traction for drag racing. That is why you see alot of 15's with tall profiles at the strip. A lower profile tire gives you better response and less sidewall roll for a better handling tire. Having said all that I don't think you will notice a difference from 17 to 18. I would go with wichever combo is lighter.
So 10.5 in the back with a 315 tire should fit just fine? What do people usually run in the front, size wise?
Also, do you know the wieght of the wheels?
Yeah it looks awesome from the back, and any view imo!...I can't wait. So my plan is the 10.5 with 315 in the back, no spacer and then rolling the fenders. Just need to decide on tires now... hah
Thanks, and I can NOT wait for spring to come around and bring the car back out with the new look!
