295 on a 9.5?
Old Jan 26, 2008 | 03:51 PM
tylergarceau's Avatar
Default 295 on a 9.5?
will it work, i read stickys. didnt mention it.
Old Jan 26, 2008 | 06:00 PM
musclehead's Avatar
yes it will work but not recommended.
Old Jan 26, 2008 | 08:33 PM
any reason for that? im dropping down to 285. but im jjust wondering
Old Jan 26, 2008 | 08:37 PM
00badfnta's Avatar
Yes and recommended
Mickey Thompson 3745R - Mickey Thompson ET Street Radial Drag Tires Details
P295/45R17 (28'' x 11.5'' - 17'')
Tire Compound: R2
Tire Overall Diameter: 27.2''
Average Roll Out/
Circumference: 85.4''
Tire Tread Width: 10.6''
Tire Section Width: 11.6''
Wheel Diameter: 17''
Spec Wheel Width: 10.0''
Approved Wheel Widths: 9.5-11.0''
Tire Weight: 33.0 lbs
http://www.jegs.com/webapp/wcs/store...0002_879552_-1
Old Jan 26, 2008 | 08:40 PM
im going LOW profile tho.. 30.. does that matter ?
Old Jan 26, 2008 | 08:46 PM
954mula's Avatar
Those are drag radials. If you're wanting this for daily use....should be good for a few weeks.
99WS-6T/A's Avatar
no one make a 295/35/17 or 295/30/17 at least not any company that i could find. i wish they did.
Old Jan 26, 2008 | 08:54 PM
i found alot but why do they not recomend it.. what happpens ? they blow ? lol
Old Jan 26, 2008 | 08:57 PM
i got 275/30/19 on the front.. wasnt sure on the back.. 285or295/30/19
Old Jan 26, 2008 | 11:26 PM
michaelg589's Avatar
On a 19" rim, you should not run anyhting larger than a 285. On a 17 inch rim, sure. there is more sidewall for the tire to conform to the rim width. When youre running a low profile tire there is very little give in the sidewall to "squeeze" onto the rim. A 295-45-17 will fit fine on a 9.5" wheel. Thats a big sideqwall. But a 295-30-19 would be pushing it on a 19x9.5" wheel.
Old Jan 27, 2008 | 01:40 PM
pozesd99''s Avatar
i run 295 35 18's on my 9.5's all the time. no regrets
Old Jan 27, 2008 | 02:49 PM
Again the sidewall is slightly bigger.
Old Jan 27, 2008 | 03:24 PM
pozesd99''s Avatar
true dat lol
