15 " front rims
Old Feb 23, 2008 | 02:19 PM
Dragkid1917's Avatar
Default 15 " front rims
For racing, I wanto use 15 inch rims with skinnies, Do they fit or do I have to trim the breaks to make them fit or what? There probably the exact same demensions of a Weld 15 X 4 Racing rim.
Old Feb 24, 2008 | 06:27 AM
Camaro396's Avatar
Bogarts or Convo Pros will fit without grinding, and Weld Prostars and Draglites will fit with a spacer and ARP 12mm 3" Wheel Studs.
Bad picture but I have 15x3.5 Draglites in the front, and stockers in the back with slicks.
Old Feb 24, 2008 | 09:18 AM
DKITCHEN's Avatar
I was thinking about using the 15x4 TT2's so they would match my rear wheels. A little bit expensive, but I'd like to match without buying new rears. The backspacing is only 1.5 inches and alot of the others I've seen have 1.75. Anyone know if they'll still fit ok???
Old Feb 24, 2008 | 10:07 AM
Camaro396's Avatar
They might clear with a spacer, but I am really not sure. I dont know how their rim hoop design varys from Welds, Bogarts, and ect.
Old Feb 24, 2008 | 10:20 AM
sixvi6-camaro's Avatar
I've read several thread where people want to run them but Nobody has bought them and tried. As Camaro396 said the designs differ so nobody will know for sure until someone pulls the trigger and buys a pair.
Old Feb 24, 2008 | 06:49 PM
DKITCHEN's Avatar
I guess I'll be the guinea pig! I'll post up (hopefully) some installed pics in the next week or so.
Old Feb 24, 2008 | 08:23 PM
CAJUNCARNUT's Avatar
Thumbs up Summit Star Rims
Just Bought The Summit Star Wheels, Like Weld Pro Star Wheel, 15"x4" Rim, They Fit My 1996 Camaro Ss With No Grinding On Brake Calipers, Its Tight, But Thet Do Not Rub Anything, Tire Size 165/80 R15
Old Feb 25, 2008 | 01:00 AM
DKITCHEN's Avatar
What's the backspacing on those 15x4 fronts?
Old Feb 25, 2008 | 10:18 AM
Camaro396's Avatar
1.75 I believe.
Old Feb 25, 2008 | 11:01 AM
DKITCHEN's Avatar
So unless I'm thinking backwards, the TT2's have 1.5 inches of backspace leaving an additional .5 inch between the mounting plate and the spokes of the rim? The spokes on the TT2 also curve out pretty significantly giving additional clearance for the caliper. With my 17x9.5s it seems that I have 2 inches of space between the spokes and the mounting plate. With the 15x4's with 1.5 inches of bs I should have 2.5. The rim may stick out 1/2 inch farther, but I think that's acceptable. Am I thinking backwards???
Old Mar 5, 2008 | 08:49 PM
cabesas's Avatar
did you get any pics?
