15x10 & 15x3.5 Prostars
Getting ready to order these, what size spacer does everyone run in the front? I don't really want to use a spacer in the back but if it cuts down on a lot of grinding I will. Do the rears stick out bad with a spacer?
Summit part # for the spacers and/or the lugnuts?
Thanks
Thanks
nice wheels..i'm getting mine on tuesday. i think u run the 7/16 maybe. i guess if u do a lil more grinding u dont need spacers in the front. dont really like the look with the spacers
Its in the post but here ya go... Hoosier QTP 28 x 11.5 x 15
No BFH mod, or fender lip problems, it is close but they fit. I had HAL's on all the way around. Stock ride height in the rear, but i set the front down some with the HAL's Spacers are no problem to run, I ran this setup on the street all the time. You just can't use spacers with stock studs, dont even try. Get yourself the longer ARP's.
Location: Your girl's back door giving her the long stroke while you're at work
Thanks for the compliments fellas. That was my old one, I would like to prolly do something like that to my red one, but not sure yet. To answer the questions though, they do fit, it can be done. It just takes a little work and the right parts to do it right/safe.
Heres my setup.
Greg Weld 15x3.5 fronts no spacer or grinding ARP 12mm studs
Weld Prostar 15x10 7.5 backspace rears 7/16th spacer 275/60/15 tires 12mm studs
Spacers I used:
http://store.summitracing.com/partde...5&autoview=sku
Wheel studs used:
Lug nuts used:
Spacers I used:
Wheel studs used:
Lug nuts used:
