c6 wheel/tire ??
Old Apr 22, 2008 | 03:30 PM
johnnydje's Avatar
Exclamation c6 wheel/tire ??
will these fit without problems{sticking out or rubbing} on my 98 camaro ,what about spacers? frts 18x8.5 w/245-40/18 and rears 19x10 w/285-35/19.off 2007 vette
Old Apr 22, 2008 | 09:04 PM
BandDirector Blk98ZM6's Avatar
LOTS of info if you do a search....
1.25" spacer will be required for the rears to fit. Fronts will fit fine with no spacer.
Old Apr 26, 2008 | 04:30 AM
badinfluenceRS's Avatar
Just mounted mine today. I used 1.25" spacers on the rears with no body modifications.
The rear wheels will stick out a bit but nothing too bad.
Old Apr 26, 2008 | 04:54 PM
What size tires did you go with? Are you lowered any?
Old Apr 27, 2008 | 08:17 PM
1998Z28LOADED's Avatar
Im lowered almost 2". I have the stock c6 wheels with 295/30/19 & 275/35/18. 1 1/4" adapter in the rear. I had a tiny spot that took bfh and had to roll the fenders.
Old Apr 27, 2008 | 08:35 PM
95GreenZ28's Avatar
Looks good man
Old Apr 28, 2008 | 11:36 AM
stock springs but they have 190,000 on them and the front looks lower than stock, going to do the heater hose mod in the back.
i'm running stock size '06 C6 tires (285/35 rear and forgot the fronts)
Old Apr 28, 2008 | 06:57 PM
