Stiff Sidewall or wrinkle wall?
They have both versions in 26x10x15 ET drags. I am going with only a 26 inch tall tire because I am only running 3.89s in my automatic.
The car should be running around 11.80 or 11.90 at about 113-114.
I have 3:89's in the 9" along with some ET Streets, 26x11.5x15... I need more seat time for some tweaking as its a new set up and added some weight with the cage.
Last year I cut a 1.45 60' on a 255/50/16 MT DR.// So far on the three runs I have done so far this year have been a 1.65 / 1.60 / 1.55... Im going back this friday to play around at the track.
What converter you have?
How fast you plan on going and what are teh HP levels you are looking at? Unless you are doing some serious trans braking or got a shitload of power coming on down the track a slick might be overkill.
Some have said that the reason my 60' has been slower is from going from my DR to an ET street... It mightbe true but I am still playing around with the new set up. If that is the case I will go back to a drag radial. Still too early to tell.
ET Streets are bias ply correct? So I could still run the ET fronts which is what I really want to go for because of weight savings, right?
A buddy just bought the 255/50/16 hoosier drag radials and will be testing those out this friday along side me. He would go wider but he has a 8" wheel and I have a 10" wheel so I can use a fatter tire. He has a 402 stroker on a 5000 stall.. So, that might be a tire to look into as well..
If he keeps breaking those loose he wants to try out my 11.5 ET Streets to see if it helps. I can usually keep the same set of tires for ~2 seasons. I live up in Minnesota so we cant race all year long like the sothern states do. Tires are consumables, so maybe not try and do a john force burnout. lol
Here is a pic with my new drag set up I finally got this year.
Are those Bogarts? They look really great, I think I am going to go with welds though because I can't justify 700 dollars more when I could grind the calipers a bit.
You will be fine with either the 26x11.5x15's ET Streets or 275/50/15's (I think thats the equivalant size) drag radial.. Im going to try the ET Street until it gets bald then buy the DR next and see how the car likes that. only way to find out is get it mounted and hit the track. You got a hell of a deal so maybe get a set of both.
