VATS question, help needed
Old Jan 5, 2009 | 11:49 PM
paulc87's Avatar
Default VATS question, help needed
I have already done the VATS bypass and had it disabled in the PCM. But the VATS system still keeps me from starting the car intermittently, usually several times in a row. Sometimes the light will flash and I will have to move the steering column up and down while turning the key for it to start. Other times it will be the solid light that everyone is used to. Also, the light comes on while I am driving for several minutes after startup.
I'm not sure that it is the ignition lock cylinder, but I just wanted to confirm this before I take it to the shop. Any suggestions will be very appreciated.
Thanks
Old Jan 6, 2009 | 10:59 AM
WhiteBird00's Avatar
Ungrounded Moderator
If you have done the VATS bypass correctly, the ignition cylinder is not in the circuit at all. You could be turning the ignition on with a screwdriver for all it cares. I would double check you bypass wiring - make sure nothing is loose and that it is all well insulated.
Old Jan 7, 2009 | 04:06 PM
paulc87's Avatar
So you think the security light coming on while driving has to do with the bypass making a bad connection? I may just have a mechanic remove the bypass and replace the lock cylinder so I don't have a bunch of resistors rigged up under my dash
Old Jan 8, 2009 | 08:41 AM
The ONLY cause of the security light in the instrument cluster (not the alarm LED on top of the dash) coming on is a problem with the VATS system. If the light is on steady then the BCM is reading resistance that doesn't match its stored value. If the light is flashing then the BCM is reading an open circuit (infinite resistance) indicating that the key has no resistor pellet or the wires are broken somewhere.
Old Jan 9, 2009 | 10:54 PM
paulc87's Avatar
Thanks for the information WhiteBird, I took it to the shop and it turned out that a faulty ignition switch was the culprit. Haven't had any trouble starting as of yet
Old Jan 10, 2009 | 07:22 AM
badmfkr's Avatar
Default Vats
I was told by a GM mechanic that changing a ignition switch would also require changing something else can't exactly remember what else he was referring to just remeber he wanted around $500. to change ignition switch.
Old Jan 10, 2009 | 04:57 PM
That mechanic wasn't thinking clearly or was trying to sell you something. He was probably talking about changing the ignition cylinder - not the ignition switch. The ignition switch is just an electrical switch at the lower end of the steering column and it can be replaced without affecting anything else.
The ignition cylinder is where you get into the possibility of needing a new ignition key which could lead to a new BCM to match the resistor pellet. But that's only necessary for those who don't think about what they're doing. The only way an ignition cylinder would come with a key is if it's used. A new cylinder comes ready to be matched to the existing key (insert the existing key and grind the popup tabs down to the surface of the cylinder). But even if you get a used cylinder, you can still measure the resistance of the original key pellet, get a matching key blank, and cut the blank to match the cuts of the key that came with the cylinder. In any case, no new BCM would be required.
Old Jan 12, 2009 | 01:09 PM
paulc87's Avatar
What you said makes perfect sense, but he said it was making intermittent contact and that's why he needed to replace it. He only charged me $130 to make the repair. I haven't had a no-start condition since that day, and I don't get the security light while driving anymore.
Old Jan 12, 2009 | 01:26 PM
m6speed's Avatar
about time you got that fixed paul
Old Jan 13, 2009 | 07:27 AM
Well, obviously he "discovered" he could replace it without it costing $500 (IOW, he didn't have to replace the BCM as well). I'm glad you got it working without getting raped by the mechanic.
Old Jan 15, 2009 | 02:23 PM
its turbo time's Avatar
i had mine bypassed, and now only when its freezing outside i'll get the solid security light. followed by a nostart situation. it almost always comes back and lets me fire it up, but this morning its not letting me!!
Old Jan 15, 2009 | 02:54 PM
Sounds like the resistors used in the bypass are marginal. You might try taking a hair dryer to the area around the steering column behind the knee panel to see if warming it up brings the bypass back online. Then you can look into the resistor problem when you get a chance and it's warmer out.
Old Jan 15, 2009 | 05:02 PM
^^thanks! i eventually got her working by rocking the tilt back and forth and then hitting again after a couple minutes passed. Im gonna try and find some better resistors in the mean time for sho.
Old Jan 21, 2009 | 11:02 PM
paulc87's Avatar
Just wanted to let everyone know that the fix has worked fine for I guess 3 weeks now, but I am starting to get the security light illuminating the entire time I am driving. I've never had a no-start condition so I guess it's not a big problem.
Old Jan 24, 2009 | 01:34 AM
paulc87's Avatar
I guess you were right all along WhiteBird00, I tried to start it today and the car alarm will not stop going off, and the car will not start period. Even when I open my unlocked door the alarm will start again and run for 2 minutes or so. Any ideas appreciated
