Rewiring headlights - where to start?
I want to wire the whole system with some 12ga wire, but my question is where do I start wiring from? So far I hear just to splice right after the relay, but I want to go from the source. Ive heard to start from the headlight dimmer switch, anyone have any ideas?
There is no reason to go before the relay, if the relay trigger still works. also no sense to have longer wires than necessary, so running back into the cabin, to the weak headlight switch is just silly.
This is how I wired my HID’s, I pulled the source of my relay trigger from the 5 pin weather pack connector, I remove the old terminal, and installed my own (I HATE cutting any factory wiring, so I decided to do this method) I installed a relay under the fuse boxes and a weatherproof fuse holder under the fuse boxes. I ran 14 gauge wire to both HID ballasts, but if you do not have HID’s just run the 14 gauge to your new headlamps
Ryan
its really just for simplicity's sake and that way its easy to run fresh power right from the battery to the headlight's.
Correct me if I'm wrong but thats what i think he was getting at.
EDIT: a quick scan of the schematic, i cant find a relay for the headlights. but the idea is the same, just make the normal power for the headlights a signal wire (with a relay), to pull power direct from the battery.
turn your headlights on,
power goes to 85 turns on the relay
connects 30 and 87,
then you have power to your headlight
the headlight turns on
the other pin on the headlight is ground of course.
