"low oil" light came on
Old Mar 23, 2009 | 06:58 AM
69lemansguy's Avatar
Default "low oil" light came on
ok, so i removed the pcm this weekend to route some new power wire through the gromet, put the pcm back, and continued to work on the rest of the stereo, didnt drive the car all weekend. hopped in the car this morning to go to work, and i notice that the low oil light is on. has never come on before, oil pressure looks good, car runs and sounds fine... so could this light be on cuz i messed with the PCM? or do i have an issue? i was going to go back outside and check the oil in the next hour or so, whenever i get my first break. any advice would be awesome! thanks guys
Old Mar 23, 2009 | 08:40 AM
TeeRod's Avatar
I'm sure this a rhetorical question but, did you check the oil?
Mine has only come on at low oil once. And it didn't go out right away after adding, it stayed on awhile.
Old Mar 23, 2009 | 08:43 AM
greyghost4x4's Avatar
Banging some gears
prob just the sensor on the oilpan finally went bad.. its like a 17 dollar sensor(i think?) from gm dealer. my low oil light is on as well and has been on for several months now b/c i'm just too lazy to fix the sensor even though i have on sittin right here next to me on my office desk! lol check the oil first, then pull the sensor harness off the pan and check it for voltage.. very simple to do. im not 100% certain about voltage but i believe it should have atleast 5volts.... maybe someone else will chime in here
Old Mar 23, 2009 | 08:55 AM
havent checked the oil yet cuz i havent had the chance since i got to work. But i have no leaks and it doesnt burn any... If its just the sensor, i could live with that. hopefully sometime before lunch i can run out there and check the oil.
Old Mar 23, 2009 | 09:54 AM
ghettocruiser's Avatar
Its not hard to break a wire when messing around with the PCM harnesses. The wires arent exactly the heaviest gauge in the world.
Ive heard of the level sensors going bad...but Ide do some testing to see for sure.
Im not sure how low you have to be for the light to come on. I imagine it would come on well before it got dangerously low. Well before you'd lose oil pressure from low oil as well. But for goodness sakes...dont even start the car again until you check that oil. It does not take long for the engine to start eating itself if it doesnt get what it needs oil wise. Probably should have checked it before even posting haha...might have answered your question pretty quick.
Good luck.
J.
Old Mar 23, 2009 | 10:38 AM
i wanted to wait to check it until it had cooled down. im taknig lunch in a few min, so im gongi to go otu there and make sure its where its supposed to be.
Old Mar 23, 2009 | 10:49 AM
vjo90rs8's Avatar
I guess you can check it cold but you should check it at operating temperature if you want to get the most accurate reading.
Old Mar 31, 2009 | 05:54 PM
landstuhltaylor's Avatar
I had the same problem on my LT1 for the longest time. If the oil is fine definitely check the wiring, mine was broken right next to one of the connectors.
Old Apr 1, 2009 | 11:50 PM
PONTIAC SLP's Avatar
i have the same problem my low oil light is on from a while and i don't know from what is that , i think from the sensor , from where can i buy the oil pan sensor ?
Old Apr 2, 2009 | 02:07 AM
02 BLK WS6's Avatar
Don't listen to this retard. You want to check the oil with the engine off for some time to let the oil settle. You check the transmission at operating temperature.
Old Apr 2, 2009 | 02:22 AM
Sharpe's Avatar
i guess you can check it cold but you should check it at operating temperature if you want to get the most accurate reading.
what?!?!
Old Apr 2, 2009 | 10:22 AM
vjo90rs8's Avatar
Originally Posted by Sharpe
what?!?!
Are you guys re-tar-ded. Operating temperature means with the oil AT operating temperature. If I have to spell it out, it means, start the car, let it warm up, turn the car off, let the oil settle into the oil pan for a few minutes, then check the oil level. I was assuming everyone knew how to change oil and was just saying that it is better to check it with the engine oil at operating temperature as opposed to being cold. No where did I say check the oil while the car was operating.
Old Apr 3, 2009 | 11:16 AM
WhiteBird00's Avatar
Ungrounded Moderator
Ah yes... but they were surprised that anyone would feel it necessary to get the oil to operating temperature just to check the level. Doing an oil change is one thing - you want the oil warm so that it flows more easily and therefore drains from the pan faster. But checking oil level has nothing to do with oil temperature. The difference in volume between warm and cold is so small that if you're that close to being low then you need to add oil anyway.
