Antenna Options
Old Nov 1, 2003 | 07:51 PM
ApacheDrill's Avatar
Default Antenna Options
The whip antenna is not cutting it, i know that there are the electric ones but what other options do we have? Any pics or advice on this will help. Thanks
Old Nov 1, 2003 | 07:54 PM
maddboost's Avatar
What do you mean the antenna is cutting it? Bad reception or you just dont like the looks? If its a looks problem Metra makes a replacement power antenna. I think for some reason they only make it for the Firebird but its the same mount for a Camaro.
Old Nov 1, 2003 | 08:33 PM
I was just think it looks plain, the power antenna may be the way to go if i dont find anything else.
Old Nov 1, 2003 | 08:38 PM
firebirdude's Avatar
I bought mine from www.rksport.com but it's like $100. I also found a flexable antenna on Ebay for like $8, but obviously it's not for us power antenna guys. It's just has a bolt with threads on the end. Came with like 5 or 6 screws. Obviously a "one kit fits all" thing.....
Old Nov 1, 2003 | 08:53 PM
Thanks
Old Nov 2, 2003 | 02:57 AM
FenixSS's Avatar
Did it fit well? Heard it's a witch to put in since it's like a universal kind of power antenna. Pics?
Old Nov 2, 2003 | 05:31 PM
It is a universal kit. But it was still pretty easy to install. No pics, sorry. It's been a while since I did it. Over 2 years. But I think you use the adapter with the most slant. You'll know what I'm talking about when you see it. And I think I had some problems figuring out which wire connect to what. I think I just guessed and got it right. There's only about 3 wires to choose from. If your just looking for a replacement antenna, get the stock one. It's only like $65 and, of course, it's a direct fit!
Old Nov 2, 2003 | 06:06 PM
FenixSS's Avatar
Yea, getting conflicting reports though about it. blackcamaro.com has a section on installing the GM power antenna, but you still have to go and buy several parts from like Radio Shack, Home Depot(plumbing dept) and even though it a sweet setup, goes up ONLY when listening to radio, automatically goes down when listening to something else. Also, not as 'waterproof' as the RKSport one.
Old Nov 2, 2003 | 07:31 PM
I have had no waterproof problems with my antenna. All it takes to keep your antenna from going up and down every time the radio comes on, is a simple toggle switch. Get em' for liek $3 from Rat Shack. Add $1 worth of wire and bingo..... if I had the choice to do it again..... I'd go with the GM.
Old Nov 2, 2003 | 08:37 PM
FenixSS's Avatar
Thank you for your insight
