Is Kee Audio gonna have a sale soon?
#41
Well i got both sets in finally. I still have the stock speakers in the hatch area (they provide nice fill) but it is not a perfect 1:1 match front-to-back. I can definitely live with it though as long as I push the fronts on my HU by about 1 or 2 notches. I know it is because of the impedance mismatch. You are 100% correct about getting both sets in. Wow, what a difference! I actually had to turn the treble DOWN for once!
The one thing that bothers me a bit is I have quite a bit less headroom in terms of volume. I have to turn the volume up a bit more to overcome the impedance mismatch with the front speakers. Can anything be done about that?
The sound is 1000% better than stock up front and wayyyyyyy better than the crappy Sony coaxials that were back there. I am not quite sure what they were, but I know they were Xplod speakers. They named those right!
BTW:
BTW:
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
#42
Probably been asked a million times but!!!!
What would be the best sound upgrade as far as speakers for a 2000 Camaro SS monsoon system. I don't want to change the head unit. I would like a deeper bass and more mid sound. I also don't want to hack up anything to get them to fit.
Thanks in adavance
Troy
Thanks in adavance
Troy
#43
Kee Audio can definitely help you out with that! The same CDT speakers that he sent me can be converted into coaxials, but still wired as components. Unlike the Firebird/Trans Am's, the Camaros AFIAK have components mounted as coaxials, but wired as components.
Also, the subs in the Camaros are SVC (Single Voice Coil) subwoofers, as opposed to the Dual Voice Coil subs in the Firebirds. I think his Bazooka subs will still work, you might have to do some different wiring though to get them to work with the stock amp.
#46
The standard package still has quality CDT components (CL-61CV) up front, the major difference is they handle a little less power and have stamped steel baskets vs. the cast frames in the other package (CL-E61CV). The drivers still uses a phase plug design to lesson higher end distortion and both use silk tweeters for crisp highs. The Bazookas are true subwoofers and will produce better bass then stock and handle more power without distortion. The materials are superior to the stock paper and foam so they also last much longer and can handle more abuse. The CL-6 in the premium package are midwoofers but can have extended range so they will hit the lower frequency bass but can also handle midrange.
#47
By the way...I was out of the KD-R800...forgot to tell you on the phone...you are getting an upgrade to the KD-A805 which is the Arsenal unit which has built in bluetooth with the bluetooth adapter included, 2 year warranty over the standard 1 year, and 5 volt preamp outs (over the 2.5volt RCA's). Still has the TI/Burr-Brown 24-bit DAC also. Very nice unit!!
#48
He gets a whole bunch of goodies tomorrow!! This should be a nice, sound quality system using JVC HU, CDT speakers and JBL subs and 5-channel amp.
you sure it is supposed to be today?? waiting suxxxxxxx lol
