HELP! With Monsoon Radio
Brent
Enter your secret code as follows; pause no more than 15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MIN and 000 will appear on the display.
3. Press MIN again to make the last two digits agree with your code.
4. Press HR to make the first one or two digits agree with your code.
5. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show SEC, indicating the radio is
now operable and secure.
If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three more chances (eight tries per chance) to enter the correct code before INOP appears.
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 06010, press the * button and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press the minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on the radio
To remove the code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
https://ls1tech.com/forums/general-lsx-automobile-discussion/597972-stereo-lock.html
Here are some others:
https://ls1tech.com/forums/wiring-stereo-electronics/159174-theftloc-help.html
https://ls1tech.com/forums/wiring-stereo-electronics/113479-how-turn-off-theft-lock.html
https://ls1tech.com/forums/wiring-stereo-electronics/348600-help-monsoon-loc-d.html
https://ls1tech.com/forums/wiring-stereo-electronics/110585-monsoon-cd-player-question.html
https://ls1tech.com/forums/wiring-stereo-electronics/56372-theft-lock.html
https://ls1tech.com/forums/wiring-stereo-electronics/159979-monsoon-security-lockout-feature-bypass.html
WhiteBird00, can you update the sticky with the other codes that have been found (a few are listed in the links in the first thread)?
Jax
Hay ..glad to have been able to help you..happy holidays! Right the security code down and save it for future battery unhooks..
so here is the story. I replace the speakers they made a squeel and then just stopped working. took the replacements out still nothing. checked the fuses they are ok. the radio Lcd works reads the station and the song playing. checked the power to the amp and its got good power. I just want my tunes back please help!
I think the new ones were 8 ohms. So i kinda screwed it up. so sombody said you prolly fried your amp. well now I replaced the amp and it still dosent work. I got some replacement monsoon speakers didnt put them in yet even without the rear subs the system should be working. looking for a little help does anyone know what could be wrong?
I didnt try the code because there is no error on my lcd display
