new hu and speakers..dissapointed
so i just got done puttin in my midbasses from key audio, i'm stumped on the components for the front, not sure how i'm gonna do it....anyways, installed the new kenwood x993 and with it and those midbasses and the stock fronts it sounds terrible, no punch at all....have i done something wrong or is there no way around this without buyin an amp
is there no way to make the stock amp work?
Have you made any adjustments to the settings on the HU yet? You can't just throw in a new unit and expect miracles. There is generally nothing wrong with the stock amp. Amps only amplify what is given to them. Now you've gotten a cleaner signal but if it is in a default factory setting it is not going to sound great.
The installation for the speakers is straight forward. Remove the door panels, remove the stock midbass and tweeters (tweeters are glued in in addition to the the screw so you have to pop it loose), cut the connectors off the stock speakers/teeters and attach them to the new midbass and tweeters via solder or crimp connectors, the tweeters can be attached to the stock bracket using 3M double sided trim adhesive tape und mounted under the stock grills, plug back into the stock harness in the doors and reinstall them, reinstall the door panel.
kee...the sound quality on my speakers is excellent but the bass is not even comparable to the stock monsoon....is that just the nature of the speakers i b ought or have i still not get it set up right
CDT CL-E61CV w/ CL-E6NEO Midbass
I just had the same problem you have, I bought the Premium system and had like zero bass. I just fixed it not 30 mins ago, the problem is the stock wiring. Pull out your sail subs and reverse how you have them wired. The stock monsoon clip is confusing. Flip your wires around, re-install and you should now have bass. Enjoy.
Not really, considering that the woofers are run full range and the tweeters just have a first order crossover. It's not suitable for anything aftermarket.
You can use just the woofer signal to run the crossover for aftermarket speakers. It's not the ideal solution, but it's far more ideal than the crap that people keep spreading about using the built in "crossover" here.
But there are practical considerations in this case. A crossover is designed to split a single channel into high and low frequency signals. The Monsoon system provides separate channels for each speaker element so using a crossover would require giving up that signal (i.e. putting a crossover on the door mid wires to power the tweeter would mean giving up the existing tweeter channel separate wiring). That results in a loss of overall output power.
Okay... let's clarify how it works. There are no crossovers in the Monsoon system because every speaker element is on its own channel. However, there is signal filtering to certain channels which accomplishes much the same thing as a crossover.
In Camaros, all eight speaker elements (including tweeters) are powered by the amp. The sail panels get low-pass filtered signal, the door tweeters get high-pass filtered signal and all other speakers get full-range signal.
In Firebirds, the front and rear tweeters are powered by the head unit and all other elements are powered by the amp. The amp provides low-pass filtered signal to all four sail panel channels for the dual voice coil subs there. All other channels get full-range signal. The head unit provides full-range signal to the tweeters but there are inline high-pass filters in the wiring a few inches from the tweeters.
Can someone provide evidence that the woofers have a low-pass? Because I don't think that to be the case. I actually hooked up some coaxial speakers to the woofer line and they sounded rather full-range to me. (And yes, I know that a filter, especially if it were only first order, would still have some highs, but trust me... there were plenty of highs here)
I am almost 100% certain that the only low-pass in effect is the actual inductance and native response of the woofer itself. I do not believe there to be a separate filter at work on the woofers in the front.
