Amp wont turn on
No big deal, it's normal for them to do that when you turn it up REAL loud, so I turned it down and it came back on and it worked fine.
Fast forward 15 minutes cruisin down the block...crank it up, goes into protection mode...wont come out...no lights no nothing.
It lights up blue when normal and lights up red if blown or there is something wrong..but nothing at all.
Checked all fuses, ground, power wire, remote turn on, everything. Will NOT come on. Makes a pulsing noise when the remote turn on is connected so I know the connection is good in the dash.
I'm stumped.
Oh and did you try unhooking the subs? Just a quick thing to check sometimes a loose wire on that end cant put the amp into protection too
Last edited by WhiteBird00; Mar 23, 2010 at 07:39 PM. Reason: Merge consecutive posts
No ill check that...had no idea that a loose wire could cause the amp to go into protection mode.
Last edited by WhiteBird00; Mar 23, 2010 at 07:40 PM. Reason: Merge consecutive posts
A large majority of people other then those who have there gains way to high will play there stereo at loud listening levels and never hit protection
I'm stumped.
